So ghey. Needs more 1JZ foo!
See you Sundy big guy. :wub:
How about an sr20 cortina ;)
But yes definitely keen for Sunday, I should fix this exhaust leak but don't want up fark anything up before then.
i fitted my front camber arms yesterday and wound a bit of neg into it (moreso for looks lol)
Also had it out for qr happy laps today, and it went well for being what is essentially a stock motor. My battery clamp broke so I couldn't corner to hard also cooked my pissy Natro brakes and my rears tires are now catus :thumbsup:
*note shit house front fitment as my 30mm bolt ons rub to much, so I took them off and will purchase a set of 20mm
The car looked like it went well man! Whats next on the menu?
Yer I was really happy with it, went really well for a stock motor. Next on menu in no particular order:
New tires
New brake pads
New front wheel studs and spacers
TO FIX THIS BLOODY GEARBOX!
New tires
New brake pads
stoopid question.... your gbox prob and tacho probs.... they couldnt be related could they? speed sensor issues etc?
just a thought honky!
His speed and tacho probs are just that the signal going to the gauges is wrong.
The correct signal is getting to the ECU which is doing shifts. The ECU has identified a fault with Soln A in the box, and hence locked it out.
didnt know it was confirmed as solenoidssss. thought he had checked em.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
