*very rough guestimation
Cost of car - 4750
Vinyl - ~2000
Rims - 600
Stereo - 600
Boot - 100
Rb25 - 650
B&m shifter - 300
Ecu and loom - 400
Mail order tune - 200
VZ Ls1 and auto - 2800
Conversion - 6000
Gearbox mods - 2000
Cam & tune - 3000
Plus all the other misc crap, oil, filters, tyres, care products.... It's easy over 20 :(
Butttttttttt I'm with Matt
Lol once my mods went past the initial cost of the car i decided to ignore and keep going :P
I love the thing and its worth it every time I start it. As soon as it stops make me smile ill get rid of it (not gonna happen)
And that is why we do what we do! The minute you stop smiling you slap 2 snails down the side and you are good to go again :ph34r:
It'll be getting a gutfull of spray before it gets overgrown leaf blowers put on it :P
Update:
Just got off the phone with a&t and they've informed me that the 1st and 4th bands in the gearbox are burnt (ie. f**ked) and will need replacing.... Great :(
second hand box would be cheaper at a guess mate.....
Gearbox is fixed! :woot:
Picking the thing up this afternoon, keen to see how she goes with the new Stallie, you guys know what this means....
I'll b at the drag day to keep all the six pots honest :banana:
(Although will probley still be stock motored ie no big cam/tune... Yet)
you need a gopro man.... i wanna see vids..
Agreed! We want go pro footage of skids and drag!
Not you in drag doing skids either :woot:
I'll organise some form of camera/video recording for the drag day. I'm sure one of the sau qld boys will be filming it anyway.
Ill post up my time slips when I eventually run it (ie the 29th, unless I go down to a test and tune for a bit of a practise run)
Holly mother of god, just got this thing back with the 3200 stall, FMVB and first gear. All I can say is wow... A launch from 1st gear without and foot brake stall it just flashes up and goes limiter in first and then limiter in second as it lays about 80m of black lines, I'm in shock, i love it.
These poor 235s just arnt up to the task anymore, and I may have to source some better tires for the drag day as these may aswell be plastic.
Big thanks to Trevor from A&T autos in toowoomba, great company to deal with and would recommend them to anyone chasing trans stuff in the area.
Tomorrow is my last day on my p plates, so keen to get rid of them an unleash "The Abomination" on the streets :devil:
grats on last day mo fo. road trip is needed now.....
get some mickey thompson et streets, put on standard wheels for drags.
also i have 17x8's on my 33 and i have 245's on rear. still spins like a looney. you need pineapple kit for diff....
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
