*very rough guestimation
Cost of car - 4750
Vinyl - ~2000
Rims - 600
Stereo - 600
Boot - 100
Rb25 - 650
B&m shifter - 300
Ecu and loom - 400
Mail order tune - 200
VZ Ls1 and auto - 2800
Conversion - 6000
Gearbox mods - 2000
Cam & tune - 3000
Plus all the other misc crap, oil, filters, tyres, care products.... It's easy over 20 :(
Butttttttttt I'm with Matt
Lol once my mods went past the initial cost of the car i decided to ignore and keep going :P
I love the thing and its worth it every time I start it. As soon as it stops make me smile ill get rid of it (not gonna happen)
And that is why we do what we do! The minute you stop smiling you slap 2 snails down the side and you are good to go again :ph34r:
It'll be getting a gutfull of spray before it gets overgrown leaf blowers put on it :P
Update:
Just got off the phone with a&t and they've informed me that the 1st and 4th bands in the gearbox are burnt (ie. f**ked) and will need replacing.... Great :(
second hand box would be cheaper at a guess mate.....
Gearbox is fixed! :woot:
Picking the thing up this afternoon, keen to see how she goes with the new Stallie, you guys know what this means....
I'll b at the drag day to keep all the six pots honest :banana:
(Although will probley still be stock motored ie no big cam/tune... Yet)
you need a gopro man.... i wanna see vids..
Agreed! We want go pro footage of skids and drag!
Not you in drag doing skids either :woot:
I'll organise some form of camera/video recording for the drag day. I'm sure one of the sau qld boys will be filming it anyway.
Ill post up my time slips when I eventually run it (ie the 29th, unless I go down to a test and tune for a bit of a practise run)
Holly mother of god, just got this thing back with the 3200 stall, FMVB and first gear. All I can say is wow... A launch from 1st gear without and foot brake stall it just flashes up and goes limiter in first and then limiter in second as it lays about 80m of black lines, I'm in shock, i love it.
These poor 235s just arnt up to the task anymore, and I may have to source some better tires for the drag day as these may aswell be plastic.
Big thanks to Trevor from A&T autos in toowoomba, great company to deal with and would recommend them to anyone chasing trans stuff in the area.
Tomorrow is my last day on my p plates, so keen to get rid of them an unleash "The Abomination" on the streets :devil:
grats on last day mo fo. road trip is needed now.....
get some mickey thompson et streets, put on standard wheels for drags.
also i have 17x8's on my 33 and i have 245's on rear. still spins like a looney. you need pineapple kit for diff....
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
