*very rough guestimation
Cost of car - 4750
Vinyl - ~2000
Rims - 600
Stereo - 600
Boot - 100
Rb25 - 650
B&m shifter - 300
Ecu and loom - 400
Mail order tune - 200
VZ Ls1 and auto - 2800
Conversion - 6000
Gearbox mods - 2000
Cam & tune - 3000
Plus all the other misc crap, oil, filters, tyres, care products.... It's easy over 20 :(
Butttttttttt I'm with Matt
Lol once my mods went past the initial cost of the car i decided to ignore and keep going :P
I love the thing and its worth it every time I start it. As soon as it stops make me smile ill get rid of it (not gonna happen)
And that is why we do what we do! The minute you stop smiling you slap 2 snails down the side and you are good to go again :ph34r:
It'll be getting a gutfull of spray before it gets overgrown leaf blowers put on it :P
Update:
Just got off the phone with a&t and they've informed me that the 1st and 4th bands in the gearbox are burnt (ie. f**ked) and will need replacing.... Great :(
second hand box would be cheaper at a guess mate.....
Gearbox is fixed! :woot:
Picking the thing up this afternoon, keen to see how she goes with the new Stallie, you guys know what this means....
I'll b at the drag day to keep all the six pots honest :banana:
(Although will probley still be stock motored ie no big cam/tune... Yet)
you need a gopro man.... i wanna see vids..
Agreed! We want go pro footage of skids and drag!
Not you in drag doing skids either :woot:
I'll organise some form of camera/video recording for the drag day. I'm sure one of the sau qld boys will be filming it anyway.
Ill post up my time slips when I eventually run it (ie the 29th, unless I go down to a test and tune for a bit of a practise run)
Holly mother of god, just got this thing back with the 3200 stall, FMVB and first gear. All I can say is wow... A launch from 1st gear without and foot brake stall it just flashes up and goes limiter in first and then limiter in second as it lays about 80m of black lines, I'm in shock, i love it.
These poor 235s just arnt up to the task anymore, and I may have to source some better tires for the drag day as these may aswell be plastic.
Big thanks to Trevor from A&T autos in toowoomba, great company to deal with and would recommend them to anyone chasing trans stuff in the area.
Tomorrow is my last day on my p plates, so keen to get rid of them an unleash "The Abomination" on the streets :devil:
grats on last day mo fo. road trip is needed now.....
get some mickey thompson et streets, put on standard wheels for drags.
also i have 17x8's on my 33 and i have 245's on rear. still spins like a looney. you need pineapple kit for diff....
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
    • Just to get this straight if you turn the splined shaft to the outside, it turns freely but the chain does not move? What happens when you move the chain, does the splined shaft turn? Surely the shaft is snapped, or the chain is seized and it took the teeth off whatever great is behind the steel bracket
    • Good on you for mentioning, that helps as far as other things you might need to check
