  • 1 month later...
If it isn't getting some form of boost, it still isn't a real car ;)
There will never be any form of parasitic forced induction on this car as long as I own it, id be quite happy for people to line up next to it and challenge how much of a "real" car it is down at willowbank though :P
I'll take that race :-)
FYP
And then when it's actually checked against the car I'll get raped, a dodgey modplate may aswell be written in chalk on the radiator it serves no use and you will get caught out
Man over east sucks! Half of me wants to move over there to find a job, the other half doesn't want to become a criminal just for modifying a car :/
Yep it's the sad reality of it, over here we are considered one step above dirt
Okay! I'll take that challenge... But I know I'm already nearly a full second quicker then you :P
  • 1 month later...
No unfortunately, The whole club will know when shit starts going together... Had some external issues slow up both my spare cash and my will to play with cars.
Like I said, as soon as I know you guys will know :thumbsup:
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
