Hey everyone,
I am wrecking a S2 R33 GTS T so have a whole heap of spare parts ready to go!
Check out this list below for parts and prices, if there is anything that you need but don't see here then just ask. I may have it.
R33
S2 Rear cradle inc drive shaft/brakes/cables
$200
S2 R33 Doors
$150 each
S2 R33 Boot with spoiler and hinges
$200
S2 R33 Bonnet
$300
S2 R33 Front Seats
$80
S2 R33 Rear seats
$35
R33 Rear Bumper
$100
R33 Stock Cooler
$80
R33 Front Rio
$50
R33 RHF Guard
$100
S2 R33 RH Side Skirt
$50
S2 R33 Door trims
$20
R33 Switch pack rits
$50
RB25DET Ignition coils & Plugs
$100
R33 RHF Fog Light/Indicator
$100
Seatbelts
$50
RB Radiator
$20
S2 R33 Headlight
$400 pair
S2 R33 Grill, Skyline Plate
$30
S2 R33 Centre Console
$30
S2 R33 Tail lights
$500 pair
S2 R33 Washer Bottle
$20
S2 R33 Coolant overflow
$20
S2 R33 Rear pods
$80 pair
S2 R33 Glove Box
$30
S2 R33 Boot insert
$30
S2 R33 Speedo
$50
S2 R33 Centre Dash
$50
S2 R33 Dash Surround
$50
S2 R33 Windscreen Wipers
$30
S2 R33 Suspension
$100
S2 R33 RH Control arms – Upper & Lower
$100
S2 R33 Rear steering rack
$50
S2 R33 Rear Strut
$50
S2 R33 Door Inserts
$50
S2 R33 Parcel Tray
$50
S2 R33 Air box
$150
S2 R33 Break Booster
$50
S2 R33 Hand brake
$40
S2 R33 Clutch slave & Pedal Box
$50
S2 R33 Front Steering rack
$50
S2 R33 Front Cradle
$100
S2 R33 Sway Bar & connection part
$70
R32
R32 Diff
$300
R32 Front Brakes and vertical link
$200
RB20DET Engine no loom
$400
Rb20DET Gear Box
$200
All prices are negotiable, make an offer. Need these parts gone!
Cheers,
Leong
0401 526 517
[email protected]
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
