it ain't glamorous and it ain't fun... but when you do it regularly magical things start happening... an awesome exercise if your feeling stressed or frustrated... a proper squat session is like nothing else, it gives you an awesome appetite and you sleep like a baby
and it cures cancer... obviously
my old man is nearly 70, 65kg and does 5 sets of 20 reps with 60kg... don't let a senior citizen out squat you!
https://www.sau.com.au/forums/topic/422559-squattin/page/2/#findComment-6802596
I was watching the fattest losers last night while eating a bowl of ice cream with cookies and maple syrup... and before it came back from an ad break, the commando was on giving a "TIP".
I cheered and did fist pumps like I had just won lotto..
There was the commando, Barbell on his traps.
And it goes something like this.
C - "Here is an exercise that will not only help you lose weight but also give you an all body workout and get you strong" Squats!
me - "here we go.. time to see some 1/4 squats to make sure the knees are safe"
C - "If you want, start with a broom stick to get used to the position... what you want to do is put the bar across the back of your shoulders, pull your shoulders back to create a platform there, have your feet shoulder width apart, take a breath in, then sink down and back keeping your knees out until you are at the bottom (he was well below parallel), then push back up. Everything moves up together, everything stays tight"
me - "Holy shit!!"
C - "get some weight on to the bar and start by doing 3 sets of 10 reps then increase the resistance. If you are over 40, you may need to be more careful of your joints.. I recommend *insert some brand of joint formula here*" (pumps out nice full depth reps as it fades off to an ad with the other male trainer and same joint care formula)
me - *choking on a cookie I didn't fully chew* "f**k yeah!! - Do some squats you fatties.. get that up ya!!!!"
Didn't even care that it was an ad for some shit.
Edited by TTT
https://www.sau.com.au/forums/topic/422559-squattin/page/2/#findComment-6802670
inb4 Birds' squat thread
Currently:
60kg x 10
70kg x 10
80kg x 10
90kg x 5
60kg x 10
70kg x 10
80kg x 10
90kg x 5
95kg x 2
Watch this space for big improvements, given I can only work legs at the moment. May start dropping to 5 rep sets, as my warmups are taxing me up top quite a bit...though its not as it I'm not making gains.
The ATG squat has a bias towards glutes and adductors, so I'm smashing leg press after squats to give the quads a good bashing too. After this and hamstring curls, I start walking like a zombie.
https://www.sau.com.au/forums/topic/422559-squattin/page/2/#findComment-6814200
if you want more quad work try front squats with an olympic stance
you could squat twice a week... do one day with high reps, light weight... sets of 10-20... then do a heavy day where you do very light warm ups then do 5 x 5 or even 5 x 3
in the above your mixing both... which as you say makes you too tired when it gets heavy
https://www.sau.com.au/forums/topic/422559-squattin/page/2/#findComment-6814228
Or I could squat 4 times a week, 2 for light weights and 2 for heavy :D
Good suggestion though. Might allow my legs to recover quicker too.
Can't really do front stance, as I think it will aggravate my supraspinatus. I'm lucky that i can bend my arms enough for high bar. My quads do get plenty of work, don't get me wrong...but it's nice to add that little extra with the leg press and to finish them off in a way that squats can't without losing form. I was considering mixing up the parallels with ATG so that I get a bit more quad action going on there and have more strength for getting out of a half way hole.
https://www.sau.com.au/forums/topic/422559-squattin/page/2/#findComment-6814288
60kg x 10
70kg x 10
80kg x 10
90kg x 5
95kg x 2
60kg x 10
70kg x 10
80kg x 10
90kg x 6
95kg x 3
Might add a 6th/1RM set to this so I can start using it to leverage my sets of reps and up their weight. 100 should be fairly doable for a start.
https://www.sau.com.au/forums/topic/422559-squattin/page/2/#findComment-6818205
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
