As long as you have safety bars in place at the right height, you're not going to break your neck. The body tips over forward and you end up on your knees with the safety bars taking the load, before this happens.
If you feel like this, you need to tilt the head up higher, chest out further and shoulders back further.
yeah I used to get that a bit until I started really using my rear end to power up, and stopped wearing heeled shoes
I wear powerlifting shoes, so maybe I need to focus on using my rear to power up as you say if I start squatting again.
If you are tipping forward when coming up, it means that your hip/rear is already rising faster than you can handle.
you either lack upper back strength or need to practice squatting more upright.
Front squats are good for this.
I tried to do front squats as I cant back squat due to my injury but I couldn't even front squat the bar. Can't seem to get any upper body strength going on.
Sorry I didn't know you had an injury.
Why couldn't you squat just the bar? too heavy or injury related? mobility?
yeah too heavy, I just couldn't get the mechanics of balancing the bar in front of me.. yet I was back squatting 65kg
You should easily be able to front squat the bar. Keep your head and elbows high.
Just try bw with a broomstick til you get comfortable doing it
Edit: TTT suggested broomstick as well, great minds think a like
Crossed arms sucks, I prefer the other way
Edited by Mitcho_7
Yeah tipping forward. Birds would be able to explain it better than me
Only seen you attempt it once and I forget where the point of failure was.
I'm not very good at front squats myself...arms don't quite have the flexibility for it yet.
I actually find front squat positioning/mechanics much easier to get good depth but obviously cant do as much weight.
Keeping your elbows high and head up are really the only cues I use. As soon as the elbows drop its about 20x harder I find
Edited by Mitcho_7
my injury is between L5 and S1 so even though I wear a belt it, I can't get it low enough to support that area. It's right down at the top of my glutes.
what TTT said about falling forward is really good advice. It took me a long time to learn how to sit back into a squat and use my glutes instead of shifting my weight forward and using my quads.
I was a lot stronger squatting from my quads in the beginning. Any time I felt the weight get heavy I was shifting weight onto my toes. Wasn't helped by the oly shoes I was wearing. This was until I started having crippling knee pain. Its was so bad I was hobbling around and couldn't sit for long periods without them aching.
So I ditched the oly shoes and practiced sitting back, having the weight on my heels. I would actually lift my toes off the floor as I squatted to make sure I didn't come forward. Later I also switched to a low bar position which also helped and I do a lot of front squatting as assistance. Very difficult to not sit back when front squatting as TTT suggests.
This fixed my knee pain but makes it really hard to buy pants/shorts as my ass is heaps bigger! lol
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
    • Gee she looks a bit rear heavy in that first pic! Sounds like a great project with the kids, but as I guess you know R series stuff is getting hard to find and pre that is pretty much impossible these days
