  • Replies 41
Yep, I've got them. Bought them from some speciality wiper web site in the UK. Worth every cent. Think I got both fronts for about $40 delivered from the UK, when similar blades were $50-60 EACH in Australia.
Pretty sure this was the place: http://www.wiperblades.co.uk/
No part number, I measured the stock blades and bought matching sized ones. I think one was a Mini and one was a Citroen something...
I spent ages trying to work it out. Realised rather than looking for other Nissan's they matched up to, it was easier to use the tape measure. End result is perfect, just wished I'd done the rear at the same time.
I didn't think about the rear.. hmm
ok Josh's comment got me interested, so I dug through my email and found the invoice.
Bosch AR18U - 9.24 pounds
Bosch AR21U - 10.15 pounds
8.10 pounds delivery, 27.49 total, so about $40 at today's conversion rate.
The 8.10 works out to $11.82 AUD delivery. To me, thats about what I'd pay locally for delivery, so no big deal.
I needed wipers for my daily, thought I'd try out these aero type blades. Being $11 delivered I wasn't expecting much, however these are the best wipers I have ever used.
So ordered a set for the 33 :)
http://www.ebay.com.au/itm/300817661727?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
http://www.ebay.com.au/itm/300817661915?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_2527wt_1271
Gees you make it all sound so complex- just go to Super cheap - (off memory one is 550mm and the other is 600mm) and switch them over, they just pop on off. Takes 3 mintues each side. The twin blade ones wipe away the same amount of water as the top end ones dont they...
Super cheap wanted $50 each, online theyre $40 delivered for a pair...
I might try those. Good tip, thanks.
The links you had for those blades are for another model of car though right? Not a Stagea?
    • Welcome to !
    • As I've said elsewhere, I am using the stock intercooler piping path in the engine bay, and a return flow cooler, and making ~250 rwkW (without any effort put into trying to turn it up past there just yet) and expect to be able to make some more, and frankly, I would be perfectly happy with 260-270rwKW. This is peak road Skyline usability territory. You go past there and, sure, the car will snap necks more when it's on boost, but it will also break shit all the time, cost a (even larger) fortune in tyres, etc etc. Anyway, I also do not like the over-the-fan pipe path, and you don't have to do it.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
