Fun day
Was dam Hot
Identified that the thermostat on the oil cool is not opening
Only got one tentative lap in before oil ht 130 degrees and water was at 100
Should be a easy fix though
1:51 flat
Second and third sessions resulted in blown ic pipes
Shithouse, will go over all the pipes and fix( old clap is rs and non standard which shits me as who has a 7mm socket for a Datsun) kunts
Just regular cars
Was good fun shame about the pipes
Was looking at the data and you can see how much power the car has tagging 205 km/h at the end of the straight
Lol me thinks I need a new engine and some turbos that make boost before 5k
I recon there is a sleazy 1:48 in the car as is with its current awesome powers
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
