G'day all,
How does every else with >200rwkw cars go for traction?? I have a daily driver R33 gts-t with 210rwkw and find it very difficult to get traction on the street. In first and second if I put the foot down, I get wheel spin. I could do a quicker quarter with a stock car at the moment.
Current mods that could be causing this:
-Twin plate clutch
-Hankook Tyres (cheaper)
-Tein coilovers
-265/35-18 tyres
I have a few theories:
- obviously softer (read: more expensive) tyres would help
- softer rear suspension may help????
- Would a narrower tyre (255/40-18) help? ie. greater weight per square inch of rubber on the road
I'm assuming that I'm not the only one with this problem and want to sort it out before I upgrade the turbo. No good having 260kw if you can only use it on the dyno. As it's a daily driver I'm not looking at spending too much on the tyres. Hoping to keep it under $500 per tyre and with relatively ok life.
Cheers,
Bleck
https://www.sau.com.au/forums/topic/42279-traction-probs-with-rwd-cars/
  • Replies 46
I'd go for the rear suspension being too hard theory. I believe I have the same problem as I'm running Kei Office coilovers, and there is bugger all traction 1st, 2nd and sometimes 3rd. I'm looking at getting a set of softer springs made up for the rear though as many people have mentioned before that most Japanese coilovers spring rates are about twice what they really should be for the roads in Australia and New Zealand.
well mine doewsnt have anywhere near 210kw but i noticed that with the old tyres(bald) it was very silly trying to get traction on the street coz they just spuin everywhere, i was in the same boat 1st 2nd was just spinning, however i went and got osme new tyres and they were 245/40/17's bridgestone Grid II i have to say these are better than the 255 tyres that i had on it previously, much better traction, 1st only spins a little with 2nd on spinning on gear change then she al go fromthere. maybe try different tyres, i got tein adjustables on mine and i have put em lowish, i still ran 13.5 with my shitter dude so i reckon u should be able to do at least that. twin plate may be a back foot step, although nice and strong, i think the ability to slip them isnt as good as your average organic shit one like mine
try putting in more positive camber so that when the rear of the car squats under hard acceleration there is more tire contact on the road then now with the standard settings..
i am not sure what the camber setting are on a lowered 33 or standard height car but when they get lowered the rear camber will go higher into the negative setting then there should be..
even a 1/2 to 3/4 positive camber change will not effect tire wear..anything above 1 degree will ..
or just go to a solid rear end then all your problems will be solved.. hehe go the 31's
i had the exact same problem when i had my stockies on and i only got 172rwkw since i purchased my rims (19x8) with 265/30 tyres on rear thats stopped lol their freakin heavy bastards, but yer with stockies like mentioned 1st gear a waste and 2nd gear still spinnin.
cheers...ben.
Ive got 166rwkw and i spin my dunlop 255/40r17 fm901s like they were spacesavers
They are mega old tho,
Getting Falken RT215 255/40R17 SemiSlicks next so i cant wait to see what happens
-Ive got full whiteline handling kit, strut brace and tein suspension/springs
Ive got 0 neg camber on the rear, pineapples set for traction, and a set of brand new bilsteins with lowered pedders springs.
TRACTION ISSUES. I also/STILL get axle tramp
I might go decent 255/40 instead of 265/35, more sidewall more traction?
what decent semi comp tyres come in 18" that arent 600 a tyre
i have been driving a 205rwkw 33 for a long time and now a 223kw with no real traction problems USING HANCOOK TYRES.
they are shagged and i need new ones and i can still get the power to the ground.
i beleive the susp on my car is not stock and thats probably the difference.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
