Hi guys,
I posted this in nsw thread in reply to something else but thought here is a better place. Just went to install gearbox onto new engine that has rear oil drain and twin plate clutch. On previous installs I usually angle engine down so gearbox can be attached but with the rear oil drain so close to my freshly painted engine bay I'm pretty sure it will hit. The only option I can think is lift engine off mount which isn't an issue as its just sitting there nothing hooked up, and move it forward then connect box and move both back or is there another truck in missing? I've searched a fair bit on the web and sau and can't find the answer.
Scott
https://www.sau.com.au/forums/topic/423102-r32-gtr-gearbox-install-problem/
Maybe it's a strength thing Duncan do u have any time free this week? Jez suggested lowering engine cross member which sounds like it could help but definitely with the wife and myself there wasn't enough man power to twist and maneuver that's for sure
I like to take a bit of material off the ribbing on the starter motor bump to get a little more room. After that its just some brutality to get it in. Are the clutch plate splines aligned?
when we do them, we spin 4 8mm nut's onto the engine cross member studs, and undo the engine cross member nut's, and they bottom out on the 8mm nut's.
drops the engine down about 30mm, makes a huge diffrence.
Cheers
I will have a look at that but I just had a look a there is no room to angle engine without hitting firewall so box must go on straight. As the engine is just sitting there if the cross member idea doesn't work I'm thinking moving the engine forward should do the trick .
My dad gave me a hand with the engine forward all the bolts were so easy, a little mucking around to line up engine mounts after box was attached but still less than an hour so I'm pretty pleased its in, now to all those pesky fabrication mods
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
