Hi All,
Rear wiper on the R32 GT-R stopped working. No washer jet either. Tried a known working switch to no avail. Fuse looks good. Strange that the washer jet doesn't work any more. Used to work fine until last week.
There is a small box just next to the wiper motor in the boot labelled 'amp wiper', will look at replacing it. Still doesn't explain the washer jet not working.
Any tips will be appreciated.
Thanks.
https://www.sau.com.au/forums/topic/423126-r32-rear-wipers-not-working/
  • 4 weeks later...
Sorry to strap onto this thread but does the rear sqirter have a separate water bottle and if so where is it located.
Ps. Sold 10 Wiper delete plugs this week.
Maybe one of these guys would give/sell the rear wiper motor to you ?. Just a thought.
no.
runs out of the main washer bottle from 2nd pump.
Thanks Luke
If I put the wiper motor back in I'll check the second pump up front. It's never worked. Maybe not plugged or motor blown.
Oh and I'll reconnect the tube in the rear too. For a Laugh I was thinking of aiming it to the right to squirt others.
Hey champ if ur after the rear motor I give it to u
Hey mate, have you tried replacing the wiper motor? These tend to die when brushes wear low. These power jets and blades.. Sorry that's all I know
Thanks for the tip. I haven't tested the motor yet.
There are two pumps on the washer bottle in the engine bay so I thought the rear washer ran off that, but it could be possible that there's a second pump in the wiper assembly.
Anyone have a known working one they want to sell to me cheap cheap? :P
I have one if u want
  • 3 weeks later...
Finally got around to trying the spare wiper motor I got (thank you gtr0321994). Unfortunately still no go. There is voltage at the wiper amp box thing and the plug at the motor. Looks like it's a relay or *shudders* wiring.
4WD relay also died :glare:
Off topic, but does anyone know what this is?
Found in the passenger side guard, next to the jack.
Antenna booster?
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
