I've heard some horror stories when it comes to steam cleaning, maybe it will be ok for the bottom end but maybe just be cautious towards the top end. From what I know degreaser and high pressure hose are excellent so long as you stick to the bottom end. I'm not sure what the best way to go is at the top. I was actually going to ask a similar question.
What is the best way to get the engine all cleaned up without having it removed?
https://www.sau.com.au/forums/topic/423145-engine-cleaning/#findComment-6810552
above is true but it depends on how you are cleaning it under what circumstances....if its still in the car then petrol would be a great idea but will need to scrub it....
degreaser is great but will need to let it sit for 15mins or so then hit it again with degreaser and scrub....can hose off with a water under normal pressure and should be no issues aslong as you allow drying time and are super careful
https://www.sau.com.au/forums/topic/423145-engine-cleaning/#findComment-6810736
chemtech ct18
its the best stuff ever. It is a detergent based degreaser. You duke it and spray it on, the longer you leave it the better it works. Doesn't harm anything.
Anyone who uses it is amazed. I wash mountain bikes/motorbikes/cars anything with it. It rules!
https://www.sau.com.au/forums/topic/423145-engine-cleaning/#findComment-6810883
chemtech ct18
that stuff seems good. Is it available at auto shops?
https://www.sau.com.au/forums/topic/423145-engine-cleaning/#findComment-6811380
How would that chemtech go if used to wash your car? If you use a pressure gun to get it on than high pressure wash it off would it clean the car good?
Probably best to use something a lot more mild for the paint work.
it is heaps good washing car. That's what I use.
Use a high pressure cleaner very gingerly on the paint/ bodywork, especially painted plastic, or you could remove the paint too
https://www.sau.com.au/forums/topic/423145-engine-cleaning/#findComment-6815743
it says it on the container its recommended to wash cars.
https://www.sau.com.au/forums/topic/423145-engine-cleaning/#findComment-6815769
    • I downloaded the apps (for windows) and Consult 1 doesn't have this function on it for the Consult 1 plug which I'm pretty sure all Skylines have. You would think someone would have a workaround after 30 years for all Skylines which have ABS.
    • Also, I don't know the actual ABS system on the skylines, but a sneaky thing could be a piece of electronic equipment that makes the ABS think you're moving, and then same piece can send a signal for a locked up tyre... Activate ABS without slamming brakes...
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
