Hi all,
Im looking at buying a cheapish project soon. I've found something I like but its in SA.
The car is currently registered there and it had its compliance done there also last year.
Basically I just want to know if its just a matter of me getting a rwc here in Vic and then rego or if because its not an aussie delivered car if I will have issues with complaince related stuff.
I have heard its pretty straight forwared buying an intersate car but thought I'd ask just incase.
Cheers.
you will also need to present the car to vic roads for a visual inspection, which will mean booking an appt at a location that can do that - you can't just present the RWC and pay the stamp duty and transfer as per a previously vic rego'd car. Other than that it is straight forward.
Have a look at CEVA for transport rates. I got a car from Syndey to Melbourne, depot to depot on a CEVA truck for 160 last year.
I believe that is incorrect. I did a car from NSW a while ago (3 years), and because the car was unmodified from original rego - basically original engine / chassis / VIN numbers - it wasn't necessary to have it inspected. Just take the old plates and a RWC to a Vicroads office, and pay the appropriate fees.
That may be the case if the vehicle was already registered in your name in the other state. Vic roads says you need to do all the the things you do and that in some cases a RWC is required - and to call for details. Clear as mud! <br /><br />All I know is that last year I bought a car from Sydney. To get it registered in my name I had to a)get a RWC b) book an appointment for inspection c) the inspector asked me to bring the vehicle round to inspection bay to check numbers. <br /><br />It was a 2008 Mazda MPS with no mods, so not like the kind of car to raise alarm bells. I remember all this clearly as it was around the time all the hail damaged cars were getting VIVs and every inspection center was booked out for 3 weeks - so I had to drive to ballarat to get a slot.
So his easiest shotnis t get it registered in his name in SA, keep it that way for awhile, then rego transfer?
You any register a car in a state you don't live in, and it's an offense to own a car registered in another state when you reside in another.
Basically car must be in your name registered in the state you live in.
And how would they know when you can just easily go to your bank, change your address to your mate's place, and tell the vicroads or equivalent there that you're there temporarily to find a job/internship and would like to register the car you just purchased in your name there.
If its registered in SA, and the VIN and engine no. match up with Vicroads, then you just need to make an appointment to get new plates and rego and also hand in the RWC. If the VIN and engine no. dont match up, you'll be asked to bring the car in for an inspection. You can find out exactly what scenario you have to deal with by calling vicroads and quoting the engine no and VIN to them. I am in the process of doing it now. Lucky for me, everything matches up so they don't need to inspect my car :)
I believe it's fairly straight forward if the car is stock as a rock. We got a heavily modded car from Sydney which needed an engineers certificate and that was a nightmare and a half (it didn't help that it didn't have a vin number and had to go through the stolen vehicles unit for verification prior to be registered)
I would not use CEVA transport, they are rotten to deal with and their staff are unprofessional and rude. I organised for my car to be carried from Melbourne to Brisbane in December. I booked, paid and provided all the measurements they required plus more to make sure my baby was carried safely, get to the depot after driving 150kms and was told it was going to be an additional $300 because a mistake made by their staff member and that it would take another 9 days.
Called around frantically and found another company who was going to do it $200 cheaper than the original company, carried my car in a covered truck and even gave her a wash before I picked her up. On New Years Eve. http://www.prixcartransport.com.au/move-my-car/
hmmm don't know where you got that from
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
    • To drain the Intake Heat Exchanger, there is a crappy drain plug in front of the driver's side front tyre: You should use the largest headed phillips screwdriver you had, and in my case I needed vice grips on the hose above as the plug was tight (tighter than it needed to be, since it has an o-ring seal).  After you have a tray down and open the drain, open the intake heat exchanger reservoir cap (drivers side one) and you should get a couple of litres of coolant To get to the radiator, you need to remove the plastic engine undertray. It is held on with a series of 10mm headed bolts and some clips. For the radiator, there is another type of crappy drain (kind of like a plastic banjo bolt) and you should attach a length of hose to direct the stream of coolant per this pic (otherwise the coolant hits the rad support and goes everywhere). The drain is on the rear of the radiator on the driver's side and a bit hard to find. Put a big tray or bucket down (5l won't be enough) and slowly unscrew the fitting by hand. You only want to remove it far enough for coolant to flow, it you unscrew it right out the whole fitting and direction pipe will come off and you will get a coolant bath (yum!). Undo the radiator reservoir cap and it should empty about 8l
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You also need to drain the intake heat exchanger to remove the radiator so you will need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. 2 other tools that really help dealing with coolant lines and spring clamps are Bent Needle Nose pliers Hose pliers Between them they will reduce the frustration (and injury) potential by about 1000% Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
