Hey guys just got my car tuned with a piggy back safc 2 and went to a mates property to test it out, and i reached the speed limiter, was soft i didnt notice it was speed limiting for a second.
I did check the SAFC max hold knock value and it was like 120 however i didnt hear any bad sound or noises it simply stopped accelerating.
However after that the next time i went to boost it wasnt as quick.
The car still holds boost and no bad sounds/smoke or missing. It is still as smooth as before but its like its lost 30kw throughout the rev range.
Could it be stuck in its knock map, because i cant think what else it could be?
Im going to lay off boosting it and have set a warning value for the knock to see if its recuring till ive sorted it out.
cheers
Edited by Pattey21
Yeah that the plan hope to get it on this week. When you hit high knock did you hear anything
When my car hit 100+ knock a week later it required a rebuild
Have it checked out on a dyno with some knock phones on just to be 100% sure
Couldn't hear anything
But once put on the dyno with phones on you could, bearing was ready to spin so was lucky in that sense
1st Thread - Strange Dyno Results (SAFC)
2nd Thread - Speed Limiter Reached (SAFC)
3rd Thread (to come) - Engine Blown (SAFC)
Don't say you weren't warned :no:
Well it will be getting checked out on wednesday. Guess you will have to wait to see if this turn into a trillogy.
Update:
So started taking things apart, all spark plugs were a dark medium brown/tan/earthy colour not too worried as i put in a bottle of octane boost prior to tune intending to reduce possible knock, however found out after that it can actually increase it.
Also two of the spark plugs had shit on the outside however i dont think the were seated correctly/ washer wasn't flat.
Replaced the fuel fikter too and dropped oil for good measure.
Cleaned a few sensors afm/cas/throttle.
Took for a spin all the same still smooth just lacking power. I did notice however that it did pull a bit harder with say 2/3 throttle or at least it didnt pull much harder between 2/3 and WOT.
Was watching the knock sensore like a hawk and was fine.
The problem with an SAFC is that it intercepts and changes the AFM voltage/signal. As it does this it also effects ignition timing, add to the fact many tuners will not use any form of knock detection when tuning an SAFC simply because they do not know this. So while you may get that perfect fuel curve you could be pinging at one load point. In your case i'd say because you put octane booster in for the tune it could be pinging now. He might have gotten the fuel curve right but now without any octane booster its becoming troublesome.
Thats a good point, i did talk my tuner yesterday and he was watching the knock values. also thinking it may be the fuel pressor regulator, as it did have some dirty fuel 9 months ago, could have clogged to some degree and now with the higher boost cleaned up a bit. Would explain the lean afrs prior to tuning.
Reg won't respond that way.
Ah lame,
i just dont understand why my AFRs were lean prior to tuning, if the fuel pump was dieing, then would it be able to supply more fuel when being fooled by the safc.
The green run shows no correction and a rather lean AFR. the tuner had to increase the afm signal rather than trim it which is highly unusual.
I think this is connected to my current problem
Your AFM may be at fault too, i have a similar problem ATM with lean AFR's and a mates afm fixed it.
Okay cool well ill be making a list for my tuner of what ive have done/ what it might be ill add that too.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
