  • Replies 160
Posted Images
What sort of thoracic spine injury and how did they diagnose it?
I dont know about you but if I had a spinal injury, I probably wouldnt be going to a chiro because all they do is spinal manips which isnt necessarily going to beneficial. Besides, if you have a good physio they should be able to do everything a chiro can do
Physio and Trigger Point therapist both said it was a thoracic spine facet joint injury.
I wanted to get an ultrasound last week but my GP told me to wait, maybe I should go back this week and just say I want one.
Different people are telling me different things, some people are suggesting chiro and others suggesting physio.
+1 for physio or myo as opposed to Chrio. (For me the Myo I have is head and shoulders above the physio's I've seen, they have the same anatomical understanding but also are fantastic at deep tissue massage and myofascial release techniques that the Physio doesn't go near.
I think a good SPORTS physio/Myo is better again, and there are people around my area who identify distinctly as such.
The (free) physio I see at the hospital for my ankle is always saying how great it's going but she's only thinking from a basic functionality point of view, can I walk and jog pain free for a bit? Yes then you're doing great compared to the last guy I saw who can't walk unassisted.
A decent sports centric therapist realises that you want hih level function, not just basic movement, and works towards that. I'm about to leave my free physio I think and head towards one of the sports specialists for higher level assessment and to work out how to help stop my bad foot rotating outwards and rolling inwards when load is placed on it, which f**ks squatting up badly for me, and also strains my god side as it carries much more of the load.
+1 for myo over chiro. There is one upstairs from work. I've had days where I could barely walk properly from back pain and after 30 mins on the table I'm much better. It hurts like hell while I'm getting wailed on, but afterwards I feel much better
Hammy continues to be an issue despite dropping all leg work with the exception of walking for normal daily activities and walking the dog once a night, short walk, 2ks.
I note my lower back on the same side is tight and not moving freely also, similar spot to when I had the SIJ issue.
Is there a chance the hammy is being strained by poor mobility above and below it if that makes sense?
I might go back to the myo and get another hour session and this time not train the day after it thinking it's ace.
I had dry needling done, isn't that the same thing?
It's not quite the same thing; similar principle but trigger point doesn't use needles and allows the therapist to focus on one trigger point at a time. I feel trigger point enables the therapist to get deeper into the muscle fibres.
To me your hamstring sounds like an active trigger point; referring pain either locally or to another location along a nerve pathway.
To me my hamstring sounds like aids =\
Might have to cut it off.
Hahaha awwwww Dan!
If it helps I'm feeling the exact way about my shoulder blade atm
The thought of slicing it open is actually relieving to me lol
However, since my last physio visit on Friday (this physio was a hundred times better) it's actually feeling better than it's ever been. She said she hasn't come across someone so stiff in the thoracic spine before :( She loosened me up and manipulated me. I had an intense migraine for 2 days but feeling a lot better today; just constant cracking.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
