Anyone wanna help me with info on those?
Because if they are coming out with the cams to get the head off, I may as well have SOME reference. :-\
Aircon pump, bracket, bolts all in good condition, the pump works fine. $50 come get it if you want it. Give ya the condenser for 25 bux too if anyone wants it.
OK condition clutch fan.
Free to good home. LOL.
Got to here:
Before I decided I was gonna pull it all out.
LOL.
>_< D'OH!
OK guys, seeing as I've gotta rip the intake and exhaust off to do the headgasket.
Should I just convert it to a single?
Or seeing as I have the stock head gasket, etc - just chuck the twins back in?
Stay twins, and it's not hard to do in the car, but I highly suggest pulling the sump off too and checking the oil pickup isn't blocked, which means pull the engine ;)
haha, yes.. keep the engine...
Maybe the fond memories of pulling the engine out. :P
Nah gonna yank it anyway, may as well save for an engine stand, and if anyone has an engine crane, feel free to let me know.
Gonna yank the gear box and engine in one hit.
May as well do the clutch and gears at the same time.
The car has been stripped right down to the rad support to get the engine out.
I may as well just unbolt what I can of the rad support.
Gonna have fun re-aligning the front chassis if I bang the donk into it.
LOL
I wanna pull the box and engine out together, It's gonna be hell to get the bell housing bolts undone for me - so I'll drop the crossmember and lift her out.
I realised something thisarvo.
I've pulled almost everything out of the engine bay just to do a headgasket.
DERP.
So, yeah, engine will come out, and box, gonna build 'em and slot them back in.
May have to reassemble the front end a bit while the engine is out - may have to change her storage location in the next year.
Okey doke - all the Alarm systems are completely cut out of the GTR.
All the aircon system is out bar the main cables and heater bar setup.
Pulled everything away from the front of the car so the engine and 'box can be slid forwards to split them.
Just have to disconnect all hoses, plugs etc to be able to yank the donk out.
Gonna need help to put it all back together eventually though.
Anyway.
2 AM, and I need sleepz.
Everything is coming out of the engine bay for a clean and replacement if necessary.
If I wanted to JUST do the head gasket, I would have paid to have it done.
Everything is being stripped back to the metal, I wanna make it all clean, reroute a few things, etc.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
