Hey guys,
I'm about to get some intercooler piping made up for my r33 rb25det and just want to confirm some things.
Because I have fitted a forward facing plenum and new turbo I'm planning on shifting the afm to the piping ( throttle body side) and will also have on that same piping from the intercooler to the throttle body the BOV, spot for water meth injection and a spot for the ACC valve from the plenum. Things will be tight so not sure as yet if the AFM will definitely be relocated but that's the plan. However I need to confirm what order these 4 things go in and the spacing. At the moment I think it would go in this order (being closest to throttle body first and close the intercooler last): water meth (80mm from TB), ACC (100mm from TB), BOV (200-300mm from TB), AFM (close to intercooler as possible).
If this is not correct please let me know. Any help is much appreciated.
Cheers
That would not be correct. You would want the AFM to be downstream of the BOV. Otherwise, with the arrangement you've listed, your AFM will register the flow of air through the BOV as the turbo-intercooler volume vents through the AFM towards the BOV (and then probably measure it again as it goes around again, and maybe again!).
I hope you've got a programmable ECU or it's going to be a world of pain with the AFM in the pipework otherwise.
That makes sense that the AFM should be on the throttle body side of the BOV adaptor..
Yeah I have a PFC. Doesn't make a difference if the BOV was plumb back or athmospheric does it?
So the original way is correct if its to atmo? Being BOV throttle body side of AFM?
Air that is lost to atmo that has been measured by the afm already can be tuned to compensate?
No, when I said "the above arrangement", I meant the arrangement immediately above, not the arrangement most above. That's a standard form for referencing such things.
To specifically answer your question, you do not want to vent any air, ever, that has passed through the AFM to any other position than downstream of the AFM. To phrase that another way, if the BOV is downstream the AFM, then the return must also be downstream the AFM. If you vent it out to atmosphere after the AFM, the ECU sees it as air that needs fuel and you get rich shenanigans.
intercooler > afm > bov (vent to atmo or turbo intake) > WMI > throttle body
I dont think it will matter so much with the afm that close to the throttle body cause it will re-read any incoming air...there is not enough caught up in intake piping between AFM and TB to make a difference..its probably easier to just have an atmo bov...
not sure i liek the idea of the WMI and AFM being so close together though...any reason you cant leave the AFM in fornt of the turbo?
Just want the Afm in the piping so I don't have to put a restrictor on the turbo intake. Even though it would effect it bugger all I think it'd look a little clear being the same size all the way to the filter.
Would it be easiest to just have the AFM throttle body side of cooler and have BOV turbo side and vent it back to intake piping?
Has anyone placed the BOV turbo side? I figure it would be ok if it was venting atmo cause it would be disposing hot air and if it were plumb back would be better on the cold side to recirculate the cold air back
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
    • Wife and I are still looking for a new home. One condition was a large enough garage for a full-size lift in one bay. Now if only we could find something... We've been looking for almost a year now.
    • Thanks everyone for the ideas! Sadly, ramps are a no go for me. With young kids at home, I do most of my work late at night while they're sleeping. Starting the car multiple times wouldn't be a great idea.  I'll go see one of those new long reach low profile jacks and take a couple measurements to see if they will fit.
