Hi guys,
recently purchased a pulsar gtir from interstate.A mate of mine checked it out mechanically.
I have since transpoted it to where i live and cant find compliance plate,
The car has a queensland modification plate and has a new vin stamped on strut tower beginnin with 6u.
Do you think i will have trouble registering it
https://www.sau.com.au/forums/topic/424772-cant-find-compliance-plate-on-car/
QLD 15 yr car. Means it landed here in 2005 before they killed the loophole.
Do you have the original rego still on it?
'Should' be a case of registering it in your state.
Car was bought unregistered from Victoria. I am living in Darwin
Under 15 year rule was compliance not needed.?
As I said new vin has been stamped and by the lack of things not changed if had been complianced under Rawls suggests it may have come in under 15 year rule.
Do you guys think there will be a prob ?
Compliance was needed but the scheme was different.
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
