Howdy there people,
im goin to hit calder in early july either 1 of first 2 friday's. to see wat my 32 will do. Was just wondering if any of you fellow melbournites wanted to come along ? was thinking of trying to get a few skylines down there 2gether would look pretty good and heaps of fun spanking sum v8's hehe
anyway hope to see u all on the streets and " MAY THE BOOST BE WITH YOU" :wassup:
https://www.sau.com.au/forums/topic/42497-calder-early-july/
Hi MUSH.
If you are going to organise an event.
1) Please state which exact night you are going to Calder Park. That way it is clear for all members.
2) Make sure you include times
3) melway Refs etc.
So that every member has a chance to get there no matter where they are coming from.
IF you could edit your first post to reflect these things it would be of great benefit to SAU-Vic members.
Also, there will be an SAU Heathcote day coming up. So stay tuned
https://www.sau.com.au/forums/topic/42497-calder-early-july/#findComment-871233
you need a Full-License to race @ Calder
Otherwise you are not covered by Insurance and other related things.
You are required to show it on the night :P
cost is $50 race - $17 spectators
Are there actually any firm details by the organiser ???
If not, im going to lock this... tomorrow night. As we have drag days coming up that will be officially organised.
Also, Calder is on every friday night, just rock-up and your bound to run into a few members.
Thats what happened friday night i beleive.
- ash
https://www.sau.com.au/forums/topic/42497-calder-early-july/#findComment-879143
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
