Howdy fellas, I'm looking for some advice and opinions on a clutch upgrade as I have been researching and it seems that most are either for lesser power or I cannot get any solid information for ie: price, best place to buy, etc. So basically the car is making 300rwkw and the clutch is slipping really bad(even now that it's in rwd), the car is also now rolling in gear with the clutch in.
Now the tricky decision that we could use some experienced advice with is that the turbo's on the car are capable of over 500kw/700ps/690hp and it's only the lack of internals keeping it at 300 for now. The internals are planned within the next year god willing but may get put off for another due to some other things coming up. From what I have been reading a twin plate seems to be a minimum requirement for the current power to take the abuse and there seems to be a few options here but it also seems that twins are on the limit of the planned upgrades after the clutch and a triple may be on the cards.
I'm kinda stumped though as I am pretty sure i read that Jim Berry can make single or twin-plate setups(can't remember which) to handle 500kw and vaguely remember a couple of other mentions about NPC and others. I also expect numerous other parts will break after fitting a new clutch from others' experiences here, i'm just hoping that the clutch will not be on that list for a long time even with the future power upgrades in the next year or two.
https://www.sau.com.au/forums/topic/425115-clutch-upgrade-help-89-r32-gt-r/
Thanks guys, that's quite reassuring Piggaz. Have apparently been quoted 2700 for a HKS twin jobby, don't even know if that's installation included. Where in Sydney or the Central Coast(located) would be a good place to start for good pricing and service/help etc?
if you're not going to be making silly numbers a NPC Clutch is fine, they use a larger pressure plate so you don't need to upgrade your pivot and/or your slave.
Doug from NPC tells me a 10" Carbotic clutch will hold 400 rwkWs without issue (that's what I'm using now on a stock powered R33 LOL)
My pedal feel is like a stock clutch, but however bites like a munted raver.
  • 1 month later...
    • Hey everyone. Is there a way I can get the original window sticker (maroney label) for my 1995 R33 GTST? I doubt I’ll be able to ever get it but it’s worth a shot to ask
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
