hi guys my first post.
okay I've had my GTR for about 1 year now its got 85,000 km on the clock it get service every 5,000 km. I was driving tonight as normal and i noticed it wasn't making any boost, after about 30 seconds it started making boost again so i kept diving cause i had to to get home then next minute the engine dies, i herd a noise before it died but with the loudness of the exhaust i couldn't tell you what it sounded like. I pulled over and tried starting it again but nothing just winds over and I can see one of the cams rotating, i can also hear it got some compression while winding over. So it's on the side off the road around the corner from my place there's no oil or anything on the ground where it happened or where it sit's.
Would love to know what you guys thought cause she's my baby ! .
https://www.sau.com.au/forums/topic/425122-broken-r32-gtr/
Do share your findings?
Cam failure?
'Box failure?
Electrical?
well i rang the mechanic and asked him whats wrong with it and he said its got no compression and the timing belt is good so asked him again whats wrong with it and how much has that cost and hes said i dont know and my bill is up to
$220 i said dont worry about it a take it home figure it out myself ffs. so im thinking one of the cams has moved on the cam gear im gonna look at it saturday and ill let you know. all up ive spent $340 and still dont know whats wrong with it :(
https://www.sau.com.au/forums/topic/425122-broken-r32-gtr/#findComment-6861296
yeah its weird it just stoped all of a sudden so.. and also im a mechanice i just didnt have time at that stage to look at it lol. i live in townsville .
sorry, but surely if youre a mechanic, wouldnt you have gotten it towed straight home?
why did you take it to another mechanic?
oh, cams cant 'slip/spin' as they are located by the retaining bolts.
if all the bolts snap, I suspect the gear would drop off.
possible you have a split boost pipe?
as already mentioned, skipped teeth(timing belt jump) on one of the cams.
had this happen to me.
timing belt idler collapsed on start up.
low on comp.
new belt and pullies.
and it was fine.
you were driving, so hopefully no internal damage.
https://www.sau.com.au/forums/topic/425122-broken-r32-gtr/#findComment-6864653
okay guy, like i have said i didn't have time to look at it at that stage and thought if i took it to a guy that works on them all the time he would be able to tell me what's wrong with it but he couldn't .
so I've had a look this morning and the exhaust cam is out one tooth retarded and don't know if the belt has moved on the crank gear.
so I'm asking you guys if that would stop a RB26 from running, because I'm not a GTR expert and don't try to be, still learning about them every day.
I'm going to set the timing up right and see if it runs but that's next weekend job.
thanks guys.
Edited by nammmy
https://www.sau.com.au/forums/topic/425122-broken-r32-gtr/#findComment-6865905
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
