How effective are the fuel coolers though,are they like intercoolers which are about 85-90% effective. I guess it also depends with where theyre mounted too.
Check my build thread for pics (probably back 10-15 pages) mine is setup like larger version of the Z-tune one (I think that's what Bobby said) but it's mounted under the spare wheel in a small diffuser type setup... Pretty sexy!
Finallly got to install my flex fuel sensor, its all hooked up and everything but i havent tuned the car for E85. So at the moment im just finishing off my fuel system. All i have to do is upgrade the old fuel lines so they wont corrode, when i do the full transition to E85. Currently my fuel temps are lingering around 20-36 degrees during light commute duties. Not sure if i wasted money with the fuel cooler. Its use might come into play during the summer season.
Managed to fab up a simple bracket to hold the flex fuel sensor next to the fuse.Had to remove the brake cylinder stopper as im still in the process of making spacers that will go inbetween the BCS and the brake for the sensor.
I should be running outer space quite soon when I fit a new plenum, hopefully not too much.
Another update, got my wheels back from powdercoating. Gotta say they look brilliant.The best part is that I only spent $40 a wheel to get them painted.
been trying to remove the turbo so that i can put on new gasket to stop the scream while on boost. The worst part about this is taking out the lower nuts. Its one b*tch of a job. Anyone have any ideas or techniques of how to remove it. Was thinking of grinding off a bit of the spanner for it to fit in. I would like to know how the japs fitted it in the factory because just putting on the cement on the leak was a challenging task
Also if i did remove the oil and water lines on the turbo. Does that mean that I have to bleed the coolant system again and probably do an oil change too. Im contemplating doing this, or trying to fit the gasket without removing the hard lines.
It's easy enough to do with the right tools. But the bottom nuts are much easier to do from underneath.
As for removing the lines, yes you will have to bleed the coolant but you shouldn't need to do an oil change. But should be easy enough to change the gasket without removing the lines.
  • Like 1
Hanaldo always to the rescue, thanks.I managed to remove the bottom ones by going underneath. I noticed whoever owned it before didnt do them up properly, the metal tabs where the only thing holding them from getting undone
No problem mate, I remember how frustrating a job it was the first time I did it. It does get easier! I can have the whole hot side off in about an hour these days haha.
Was the metal tab on properly? They are prone to undoing themselves over time, so they may have been done up but just loosened up a bit.
Hey man, I got them done by mobile fabrications. If you can sand blast them yourself it will be $40 per wheel but they can do the blasting plus painting for $88. From the results they did on mine i think they know their shit. They even had experience with forged wheels because you could wreck them if overheated.
Im getting my Tune done by Autotech. But have also been considering taking it to ultimate tunes. ESP said Vipecs cannot do flex tune (it was a diplomatic way off saying he cant do it). Im learning towards Autotech because he has some extensive experience with Skylines. Depends what you have also and the quality of work your after.
Lol. I started the car 40mins ago to set the gasket sealant and voila you come up with an idea i never thought of. My next turbo change will be a topmount if the permalock i put on these doesn't come out ill just rip it all out with the manifold hehe.
Ah sweet mate, yeah the rims look great.
I would be interested to see what you reckon of how it runs on the flex fuel and how difficult/expensive it is to tune. Do they have to tune for 98 and E85 and then several points in between? I was not aware of tuners in Canberra that had extensive previous experience in tuning flex fuel and had not heard of anyone else from Canberra getting their skyline tuned for flex fuel. Based on that and the fact that I already had my power fc on the car, mine just runs a power fc and caltex E flex all the time. It has been that way for 6 months at 320 rwkw and I am pretty happy, but it just means if I ever want to go to wakefield or something I would have to load the car up with Jerry cans so I would have fuel to get home. So on my next round of mods I may change the ECU. So let us know how you go
Ed said he would tune E10,E20,30...up to E90 and 98.
Should be taking it for a tune in the next coming weeks. Just have to install the injectors but im still waiting on a rail that will fit 14mm injectors and also fit under the stock plenum. So far Plazmaman fuel rail seems like it has a chance of fitting under there. Also have to find out the correct diameter o-rings for the injector on the intake manifold. Will update you.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
