Tried searching but must be hopeless at using it. Also the 25 thread is full of small turbo results.
Have a 25 with a 3582r plain wheel turbo.
I have a full 3 inch turbo back exhaust with a resonator and rear cannon on it but I'm struggling with small amount of exhaust backpressure pushing open gate under full noise.
I am thinking the dump pipe might be a tad small With the wastegate plumbed back in. I'm aiming for 500+ (currently at 471hp).
looking at what people's opinions/experirence are on What size exhaust they have.
I have enough room for 4 inch but don't want to go oversized if not necessary.
Go with posts.
https://www.sau.com.au/forums/topic/425650-what-size-dumppipe-for-500hp/
A free flowing exhaust would just make it worse I think. You need to increase the wastegate actuator spring tension to help hold the manifold pressure in.
What is your base (minimum) actuator pressure?
4" = no restriction.
Saying that, plenty of people have made 500bhp on a proper 3" exhaust with open screamers.
Personally I'd go with a 3.5" dump to tip, magnafolw muffler and a free flowing rear can of choice... Here's the thing though, make the waste-gate dump pipe larger and longer than you might think. Run it right down and merge it just before the cat in a nice long, shallow angle transition.
i have 14psi actuator springs in. its a turbosmart 50mm gate.
I cant stand the sound of a screamer pipe so plumbback is a MUST..
the gate pipe is about 60cm long joining in just before the cat area so i think having a bigger diameter exhaust in a copy of current setup will do the trick.
I just dont want to go to hassle of doing 3.5inch only to need a 4 inch down the track
There is no oversize with a dump pipe imho. 4" will work fine.
However I don't think that's your issue, you should be able to get away with a 3". Have you tried a heavier WG spring as mentioned above?
i have changed the way the gate signal is being sent and it helped sort of. its either 16psi base and wont bleed past 21psi as a single connection onto wastegate or as a 2 port connection its 23psi minimum bleeding up to the 26psi wanted.
I would like to run 18psi low and 26psi high settings so changing the spring pressure up closer to higher settings is something im trying to avoid
At what boost? 7psi is fark all spring...
I am running 26psi of spring, and after a few track days the tension has dropped back, now it only runs 19 psi off the spring. If you plumb pressure onto the top of the gate also you should be ok either way, mine easily runs a flat 32psi now with the 5 port Mac.
I have a 3 inch dump, and 2 inch off the 45mm gate. As long as they flow well and merge gradually into a 3.5 inch free flowing system you should crack 400kw with it fairly easily. Mine would be making that if I had a manual box...
22 psi, barely falls over any more than half a pound at 7700. Im running e-boost and pressure to both sides of gate respectively
Edited by abr33
Is that no fit in a r32 with a 25 in it stao? What fouled?.
I want to run plumbed in no matter what so can't include screamer. I prefer to hear the engine while its making noises not finding out after when its brokent
Edited by nick81xd
It shouldn't make noises :/
Kurtis ran 500hp with the gate plumbed back and 3inch system....
Mine is a screamer so results are irrelevant I guess.
    • A HICAS fault really should not cause the engine to go into limp mode. These cars are so old that the systems barely talk to one another. The thump might be the lockoff solenoid valve for the HICAS (the safety valve) getting closed, to lock the rear wheels "straight". I say "straight", because when my HICAS used to shit itself before I took off and nuked it from orbit, it would lock up with the rear wheels wildy non-straight and you'd need 45° of steering wheel to drive straight. Take off and nuke it from orbit. First step is to pull the smaller of the two plugs out of the HICAS CU. See if it stops misbehaving. You can also (whilst leaving it plugged in) try to get the HICAS CU into diagnostic mode by doing the pedal dance, or by connecting a CONSULT capable diagnostic reader into the car and seeing what it has to say for itself. Can't do either of these with it unplugged though. 1st gen HICAS is a ballache. I would do a complete delete. I did do a complete delete.
    • Ah. I dunno why, but I skim read your earlier post and thought the manual switch was to force it on, not force it off. I'd be tempted to have both. So, your two in series, and another in parallel with those. Or, a master arm switch, followed by the manual force on and the thermo in parallel. 6 and 2 3s.
    • Yeah been doing it in an x shape. Do you reckon it's worth putting guide coat early where the filler isn't sanded down completely smooth? Reason I ask is because as I'm sanding it one part might be level which I don't need to sand anymore but the other part might be high so I can just focus on that instead of sanding across the whole repair area. I wonder if the putty is too thin, though the area is almost completely smooth before I do it as I've already put filler prior.
    • Just 2, and inline. One switch temp related other switch driver controlled.   I'm nearly in my head back to Arduino land for it...
