Lol nothing random about that.... Lucky your car is a nice stealth colour :blink:
Under the yellow street lights, my car looks white too :P
Charles it's because you're a dodgy Asian lol
We the same, you're just a little darker haha
Here are some of my stats: full license, intact.
Honda Euro-owned 3 years-0 random checks.
Skyline 33-owned 1 yr- 9 "random" checks.
S15-owned 3 months- 4 "random" checks with 2 EPA
mr2 turbo-owned 5 monts- 1 random check
Yamaha r1 motorbike-5 "random" checks.
So basically, if its import, sports car, you will be picked on. Dont let anyone tell you otherwise.
Not true! Haha. Here's my stats.
P Plates acquired in 2010 September. Cars owned along with 'checks';
Toyota Supra 7MGTE - 0 Checks.
Mitsubishi Lancer GSR 93' 1.8L Turbo - 0 Checks.
Toyota Mark 2 Jzx100 - 0 Checks.
Nissan Silvia S15 Sr20DET - 2 Pull overs, Busted for driving a turbo on P's and no P Plates the second time. Currently on 1 point challenge to date.
R32 Skyline Gts-t - 0 Checks so far :D.
S15 wasn't coincidence. It's focused hard by police :(.
Yesterday the skyline got bretho'd 3 times...
In Bendigo, they were doing everyone going into town in the morning... 10am
In Echuca, they were doing everyone going out of town just after lunch... 12pm
In Heathcote, they were pulling cars into a 4 car lineup in a service lane... Pulled in 4 cars, waved others through, pulled me in even though the lane was full so we had to wait... Once the other 4 cars moved on, I moved up to #1 and they pulled 3 more in behind me.
I've got zero problems with this... in Heathcote they had a HWP guy standing there typing rego's into a laptop (presumably checking for unrego, unlicenced or persons of interest linked to the car)
Good on them for checking for drink drivers so strongly on long weekend... On the other end of the stick, the gf overtook a truck at 149km/h (max on the PFC) because she wasn't used to acceleration... I lold.
I did that on the way home from buller... drove the whole way under the limit.. overtook 1 car and BAM... busted...
luckily the guy was a nice country copper and once we chatted about our mutual dislike for HWP he dropped it down to 119 for me.
Funny, since I've stopped driving my R33, I no longer get the Big Bopper (Coppers) seeing a white skyline & following me through traffic for a couple of km's before pulling me over.
Only twice have I been pulled over now in 3 yrs of Commondore driving:
1) 2010 - No Plates by HWP (when I bought it - had a temp.reg sticker - Legit pull-over reason I'll admit)
2) 2013 - Tail-Lamp out by motorbike cop in the Cardinia/Dandy roaming taskforce.
In the Skyline I once had HWP see me going the other way (@99km/h) on country highway - pull a big U-Turn & overtake 2-3 cars to pull me over - just for being in a Skyline. Anybody who says imports aren't targeted just for being imports is either incapable of rational thought or a D!(kh3ad.
p.s. an ex-country cop I knew at work said: "All the a$$#oles get put in the Highway Patrol car, because none of the other cops can stand being stuck with them for a shift."
I kid you not.
  • Like 1
topic has gone somewhat off topic as of late.
did a search and found this
http://www.heraldsun.com.au/leader/west/melbourne-residents-fed-up-with-hoons-in-their-streets/story-fngnvmj7-1226632009788
said biltz is ment to end august
"Melbourne has drastically changed - hoons, graffitti, violence - they are all related and need to be looked at urgently."
as car enthusiasts are considered as hoons it doesn't paint a good picture
Don't see how those three things are related...
Writers usually use public transport or walk and aren't terribly violent people...
Hoons aren't out to try and hurt people...
The only thing they have in common is the word scapegoat.
My step-uncle works for Whitehorse Council, an area that I used to live in...
They got a heap of complaints from people living on Morack Road because of people doing 60 in a 50 zone... Wide Wide road... So they put in some speed humps along the road... 12(!!!) of them to be precise.
Speed complaints have stopped. Now they get the same people calling up to complain that they don't like the noise of cars going over them and then accelerating after they go over them.
Some people just love to complain... these people also vote, so when it comes up to election time, they make it look like they've done stuff for them.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
