Hey guys I am wrecking a r32 gtst coupe the previous owner rear ended someone so no front panels are good
some of the parts available are :
tein hr coilovers - $450
veilside front castor rods - $100
cusco strut brace - $100
blitz dual sbc - $220
3'' catback exhaust - $200
complete bolt on turbo kit (chinese T04e) to suit rb20det (includes full exhaust, braided oil feed etc)
r32 gtr rear sway bar
walbro fuel pump - $80
various gauges - from $40
rear bar - $100
tail lights - $80
reverse lights - $70
rear reo - $50
boot lid (shaved) - $80
rear hubs and knuckles with handbrake shoes cables etc - $200
rear suspension arms - from $20
fuel tank - $100
rear seats - $20
mint front seats - $150
rear lower trims mint - $70
rear seatbelts - $70
interior carpet - $80
glovebox - $50
stereo surround with ashtray and new leather boot - $120
roof lining - $30
door shells - $80 each
door windows - $40 each
window regs - $60 each
engine crossmember - $120
steering rack - $80
much more available too much to list
please contact me on 0420 767 957
located in qld 4127
Cheers
Edited by SIFTY32
pics of coilovers, whats the condition?
pm'd
how much for the turbo setup?
sorry mate forgot to put price - $500
complete bolt on turbo kit (chinese T04e) to suit rb20det includes full exhaust with high flow cat, braided oil feed etc - $500
32 gtr rear sway bar - $100
the following are sold:
turbo setup
rear seatbelts
rhs door
dash
still lots here...
Gday Shifty,
Im after section from a right rear quarter panel,
Please pm me if ya can help out.
Cheers
Edited by NathanR32
you know its illegal to sell seatbelts right
No mate I was not aware of that, In saying that the seatbelts I had were from a different car that had not been in an accident (the ones from this particular car did not retract properly so were binned.
Cheers for the info anyway :)
Accident or not mate its illegal to sell second hand seatbelts....There are dedicated cops who go around and try to catch people who sell them, just be carefull its heavy fines for doing it.
And if you sell seatbelts to someone who doesnt install them propery, then they have an accident and injure themselves and cops ask them where they got em from, if they say it was you and can prove it ( like the post you made here ) you get a short stint in jail.
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
