  • Replies 269
Hi all,
Some of you may know that i was working on a digital dash for the stock Nissan ecus.
Well the time has finally come! I have got all the parts together to make 10 and already have made one to prove the concept.
Attached is a pic (taken with my phone) that shows it in action, and sitting there with the (proper) Consult connector.
It plugs into the Consult diagnostic port and displays 8 sensors at a time, in realtime.
The sensors/data you can choose from are:
rpm
speed (km/h and mph)
afm voltage
injector pulse width
injector duty cycle
coolant temp
ignition timing
tps voltage
absolute tps position (%age)
EGT voltage (if supported by ecu)
o2 sensor voltage
AAC position (%age)
battery voltage
Lean/Rich Indicator
Flags (On/off indicators): Closed TPS, A/C Relay, A/C Compressor, Fuel pump, start switch, VTC solenoid, thermo fans, and a few others.
All of these variables depend on whether your ecu supports them.
The device also has a serial port so you can connect your laptop to it and log the data. I am currently testing a program that pulls fault codes and erases them, logs data, does a fuel map trace(!), and a few other things.
You can also read the stock maps from the ecu with a laptop. And no, you can’t tune the ecu with this!
It also has a peak-hold function, so it will remember the max rpm, duty cycle, pulse width, afm voltage, water temp etc, and store it in memory for recall later...
Final price is $300AU + shipping. Those of you in Sydney are welcome to come past Unigroup Engineering and check it out (when i'm there, let me know before hand).
I can either sell a basic version which shows the variables that 99% of Nissan ecus support, or do a test on an ecu from your car so I can custom make one which reads out as many things as your ecu supports. A custom one might not work on other Nissans though.
Impakt
Just wondering if there is a programe available for a pc that will allow you to hoock it up through a com port to monitor the same info if you dont want/need to mount it in your car and might be able to show all of the senser outputs at one time.
Currently a PC program is being developed that will monitor/log the same data that the display processes. This means that you can have the dash installed with a laptop logging everything the dash displays.
There are already programs that do monitoring/logging and many other things too.
So did you want a PC program that worked in conjunction with the display, or just a program that had similar features to it?
Impakt
I plugged my mates (oosh's) one into my car but it only read one o2 and afm. I have a gtr engine in a 32gtst and his is a gtst rb20. Are they different between models?
Yes there are currently 3 models available. The generic n1 model (which works basically on all nissans except 200sx), the 200sx model (n1 model minus ignition timing, since 200sx ecu doesnt support it), and GT-R model, which is basically n1 plus 2nd afm and 2nd o2 sensor.
Impakt
Impakt
Im not sure how these units work and not an expert on computers either. Just wondering if there was a way to get a laptop to translate the signals that come back through the consult port its self without the use of the unit.
Im guessing not but just though I would ask and how.
Is there any way of linking other imput signals for such things as oil pressure senders or aditional temp sensors etc?
Forgot to ask a couple more things.
I read somewhere it will work with the piggyback style units as well, will this then show the true signals for what is actually happening in your motor or just what the original stock ecu is "seeing" after the piggyback unit has changed the values?
Also would this work with re-written ecu's that have had speed cuts taken off or written to suit bigger afm or injectors?
Sorry if any of these questions have been addressed already.
No you can't use a laptop on its own to use the translation. You need an interface between the ECU and laptop, which this display has built in.
The display has a provision on board to allow extra analog sensors to be plugged in. If your extra sensors spits out an analog voltage the display can be used to show these.
It will work fine with piggyback units, and will show what the ECU is "seeing".
Yes, it will work with chipped ECUs. I have mine working n an sr20 ecu with 600cc injectors and z32 afm.
Impakt
Yeah you can get hold of your wiring diagram and test with a multimeter to make sure the 5 wires are still going where they should be.
Alternatively, you can find someone else in Melbourne with one who can help you..
Impakt
Update: A logging program is now available, which actively logs the datastream from the NissDataScan.
This means that you can log the data AND use the display at the same time! The best thing about this is that the program is free! It's available for download
here
Note: This program will not work without the NissDataScan, and it useless on its own.
Impakt
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
