Z-tune is nice, but i'd take a Mine's built R34 gtr any day, has been my 'hero' car ever since that episode of hot version with tsuchiya and orido test driving it.
The ultimate response machine
You could always make up some big fakie "Mines" stickers for yours :whistling:
I might as well just drop an LS into it, neither will make it any faster just make me look homo...
Sounds like someone's jelly, don't be jelly Steve I still heart you :P...
But what your saying is you want me to help you put an LS in your 34 and apply the mines stickers :yes:
Having owned both in the last 2 years I feel I can assist.
The R35 is an engineering marvel handles well and insanely quick the gearbox is brilliant. If you looking for a daily driver or something thats quiet and comfortable that the cops wont look at this is the car great bang for buck.
I sold mine to own my 2001 R34 GTR VSpec II :) although not as new or as technologically advanced the 34 has a heap of things the 35 doesnt have.
1. A soul
2. Requires the input of the driver
3. Great manual gearbox
4. An engine bay that doesnt look like a nissan maxima
5. A soundtrack that you just dont get in the 35 (Mine has a T04z with external gate screamer its marvelous :)
6. Plenty of great Jap wheel choices and aftermarket parts.
7. Far cheaper in every area besides fuel :(
My 34 feels similar to a gt3 porsche in the sense that you get a lot of feedback from the car and do not feel detached like you do in the 35.
I love the 35 and will own one again as a daily because in that area its brilliant (if you want a quick daily). Although overall the true heart of a Japanese sportscar was lost with the 35 Im all for innovation although when you build a car with the intentent that a grandma can drive it it shows.
0-100km/h in 2.8sec is fun for scaring people but for the driver no skill. One example went to the drags and got an 11.1 4 times in a row with my 35 nothing I could do differently so went home.
Where as the 34 the difference in skill level and fun at the drags is amazing.
So my advice if your looking for a car that you dont want to modify and thats great on the street a newer the 35 is awesome.
If your after a real drivers car that you can work on and it will be evident the 34 is the go.
  • Like 1
:worship: Well said.
1. A soul
1. A soul
Dont say this.... want to own R35 Next at some point and i can not afford R34 / R35 GTR at the same time.
but well explained...
1. A soul
Hey! Hey!! Hey!!!
There is nothing wrong with the Maxima.
Other than that, great write up!
1. A soul
Great write up :thumbsup:
1. A soul
I can't think of anything to add to this :)
1. A soul
everyone else was quoting this....
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
