Had these photos sent today, progress on the painting side of things. Will go check out the car on Friday, might stop bye and see how the engine is coming along too. Big thanks Andrew from Kinzy paint and panel, appreciate your work buddy.
Shy? It's a build thread dude start posting.
Definitely reinforced the boot, boys made a frame under the boot, that the wing attaches too, so boot and wing are one, then braced to boot chassis so the wing and boot come off in one piece.
The car is in Vic, I am in Adelaide and I receive a lot of pictures of the build. A lot of the pictures are quite detail of the R&D and I have not ask what I can/can't share so I am just giving the builders some respect. I will share what I can a bit later on.
I've got the same wing and would not mind seeing what you have done so I can install it onto my street R32 later down the track. I think I got the 8" upright though because that was what they had back then.
Freddy will make me a dry carbon bonnet and a set of doors. Contact him if you want to loose some more weight mate ;)
Sorry to hijack - but I have some 10" uprights for this wing if you want some?
Makes the wing sit around 285mm at the trailing edge from the boot height and my racing category only allows 250mm so I'm getting some custom ones made up.
No problem I understand, we will be testing shortly if you would like to bring your car along? I've spoken to Freddie bout this as well. I already have a carbon boot/bonnet/doors/headlights/wing.... Carbon shaft and battery on the list, more important places to spend cash at the moment as its easy to get carried away, I am more interested in spending as much time in the car at the track to set it up.
Ill pm you details.
Have you got a back-up plan for the exhaust if you get flagged for noise? If PI are running a 75db and the pipes are facing the tower.... hell people still get stung on 95db if the wind is blowing the wrong direction.
Thinking maybe we should run a twin turbo set up again, what are your thoughts?
Personally i would stay with a single. Less things to go wrong, easier to work on like HKS26T said.
Plus if something does go wrong with twins, its so much more of a pain in the ass to diagnose the problem.
If you are worried about lag, with a track car you wont be spending much time under 3000rpm, and yes even at higher rpms, there will still be a slight delay with power coming on, but you can compensate by accelerating just that little bit earlier so that boost is on strong as you exit the corner.
Besides, if your setup is tuned correctly (which by the build, im assuming it is) lag should be kept to a minimum anyway.
lol, even if you sneeze you get pinned these days, we usaully do "on track events" which is 95db and they don't seem to mind much about noise, although they are pricey at about $800 for the day its definately worth it as you get heaps of track time with drivers that don't slow you down with traffic. Might have to modify the exhaust some how, we still have our old full length exhaust sitting there too
Engine is awaiting a plennum which will need some love from stu, head has been completed. I haven't had an engine to this degree before so it was interesting to hear and learn the work involved. Bout 50 hours to get the head ported and polished. Lucky our sponsor is an engine builder
We are Cryogenic freezing the engine block and parts which takes about a week to do, I have done all the research I could do on this subject but still have no idea if this works or not. I am taking the word from stu as he has previously done this, and says that the engine components wear less than those that haven't been done. Any thoughts from readers following are welcome??? Any engine builders reading feel free to jump in.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
