I got a quick question for you guys; a friend of mine lost his licence about 2 weeks ago for 6 months. However a couple of nights ago he got busted driving with no licence, and now hes got a court summons coming in the mail. Anyone else been unlucky enough to be in this position or know any1 that has got owned like this? if so what did they get in court? Just wondering what he'll cop in court cuz he's fkn spewin!
  • Replies 53
The 'SAU' penalty for driving whilst suspended is worse than death.
Everyone has choices.
If you choose to speed/DUI, DiaMD - you might (and prolly will) get busted - YOUR CHOICE
If you choose to drive whilst suspended - again ..... YOUR choice.
My choice is to recomend to your 'friend' to get a mental illness check - because he sounds like he is retarded for braking the law twice.
The penaty is - he gets what he deserves.
Simple as that.
:werd: mate of mine drove while his license was suspended for a month, so they extended it by 6 months. he drove again, he wrote off his car, broke his shoulder in 4 places, pin in his elbow, plate on the side of the head, blurry vision in one eye and he can't move his fingers up on one arm. Cops saw his state and decided not to press charges. He's a changed man now, and he's regaining use of his fingers.
damn shan
and also :werd:
brother inlaws work, if they see someone park in handicap zone and they arent obviously handicapped, he will get one of the workers to move their car infront of it and block them from getting out, then they call the cops. cops come, see this bmw blocked in handicapped zone, they ask for his lisence, he says he doesnt have it with him, they ask why, he says he lost it (not misplaced, he was suspended) so not only did this asshole lose his lisence and still drive, he brought attention to himself by parking in a handicap zone
doxxx: some guys in this world are just complete tards.. usually caries through to everything they touch.. world is better off without those sorts of people if you ask me.
Usually its a doubling of the original suspension if you are caught whilst driving while disqualified, and big whack of fines.
Guest INASNT
First time u will get off with just a fine, second they will threaten u will goal time, but most times its a suspended sentence. Still not a good thing to have a suspended sentence on your records.
B-Man
Dont preach about vic when u dont live here and know the BS we have to put up with. Also he could have just been pulled over and not being dong anything stupid, and yes it does happen here, cops r just assholes here.
me and a friend got busted dragging each other on highbury rd, my mate had already lost his licence so he quickly swapped seats with the passenger without thinking. anyways cut long story short they ended up confessing and he saidf that he was driving, and they had to go to court but all he got was a fat fine no more loss of licence
how the hell do you drive around with a suspended licence when you don't even know what the punishment is if you get caught...
Speaking from experience... If you get done and have your licence suspended YOUR DONE... ITS OVER... catch the train for a month you will be back driving before you know it!
GROW UP... BE SMART... and you will get away with so much more :)
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
