Fixed some more rust fixed under the hatch seal channel and fitted a replacement channel.
Decided to put it back on the rotator to make it easier to start fixing some of the rust and dints in the body.
  • Like 4
  • Thanks 1
  • 3 weeks later...
Decided to redo the sun roof patch as I rushed it the first time. Cut it out and rewelded a new piece in.
Brought a stud welding a while ago finally got around to converting the hand piece to take pins and made up a slide hammer from the nose of a rivet gun.
The car had been rust treated from the dealer so scraped out all the body deadener to start working on the rear quarter panels.
  • Like 3
  • Thanks 2
  • 1 month later...
  • 7 months later...
Decided to make a trolley to hold the stud welder and a few hammers and dollies so they're at arms reach while I do the body work.
Had to make one good ignition switch from 3.
Rebuilt and painted the column.
Ordered new door trims in SS style.
  • Like 2
Stripped the covers and gave them a satin finish.
Wasn't happy with the catch can/washer bottle, decided to make it a bit lower and raise the bottom to hide the washed pump and boost control valve.
  • Like 2
  • Thanks 1
Decided to buy new brake, got some XYZ 355x32 6 pot front and 4 pot rear. It might be a bit of over kit considering the hatch original came out with 13" rims and now is going to have 14" discs.A9X_0178_resize.thumb.JPG.f5afe3b722e09c04fc9cffbaf721cdec.JPG
Have 12mm clearance between the spokes and the caliper and 6.5mm between the inner barrel and the caliper .
  • Like 3
  • Thanks 1
Started on the gaps and sort out which is the best nose cone to use, then need to modify the front section of the front flares and front spoiler.
Also gave the engine covers a better polish and fitted some Mines triple flow cam baffles.
  • Like 5
Mate, you're really getting stuck into it, well done!  Looking awesome!  I know where to go for panel repairs when I buy another Datsun/Rustsun!
Things must be a bit quiet at Rubicon with all this spare time you have on your hands!?
Keep it up, I bags first test ride for an SAU member!
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
