I just noticed we have missed heaps of the helpers in the pics :O lol will try harder next time to make sure everyone is in there ;)
Thanks too all the team that makes this possible as it is EPIC!!!!
got say a big thanks to all the organisers.
as a first timer i had a ball, well worth the drive, and ill be back for more.
look forward to the next one.... as i still have plenty of tyres..hehe
Glad you got back safe! Was good too meet you breifly man!
Stay in touch as we have cruises up north occasionally, and i KNOW you're not scared of a long drive haha!
i see ur havin a cruise up wotton way?
i love that drive, my first gemini and i have some great memories of that strech of road
if im free id love to tag along
Awesome! Well if you are free make sure you come along! It is only a small cruise with a few of the Newy guys but we would be more than happy to catch up or meet you along the way :yes:
Cheers for all the pic/vid love of the v35.
Surprised at how well it went when I had a bit of room to throw it around. Was useless in the tight slalom though. But cant expect much for a sstocker on street coilovers and heavy wide 19s with china tyres :P
Probably was still more suited to this kind of thing compared to my 14 being na and haveing somw form of tourqe
Day was actually quite well run and had a better atmosphere than most eastern creek days, reminded me of the old oran park days
Edited by (Locky)
It looked sweet! loved the entrance too with the speed hump scrape and then the wooden blocks :yes: Cos low!!! There are more pics of it i think :D
Thanks to the organisers for a top day
Here is two of my vids links
Haha love that second view mate! Just had to make sure you switch the view back to desktop or it doesnt work ;)
Looooove the skid video!!!! :woot: what resolution is that in?
And yes, that was gate pressure and plumb back gate so low 300kw, car has run 391kw ;)
Hoon
Wonder how the orange go kart would go at this?
Would
It even be allowed to run?
Those speed humps massacre the cross member, rails and subframe. This car hangs lower than a s/r chassis even though its not even tucking tread on 19s
Was worse going out lol
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
    • Ahh. Well the block damage is a problem, you really need to run a tap or thread chaser through it to see if the threads can be saved, but any chips are likely to be bottom end bound which is bad. Earls seem to have what you need if you want to stick with mounting direct on the block: https://rceperformance.com.au/parts/earls-straight-adapter-1-8-npt-male-to-1-8-bspt-female.html, but as I said above I'd recommend remote mounting the sender
    • I'm not quite understanding or I'm missing steps here, (I appreciate people are trying to inform my brain but I am of the dumb, especially today) - All I want to do is mount the male BSPT of the OEM sender into the system somewhere without it snapping the adapter via vibration. The Nissan sender has a male 1/8 BSPT output. The block has a (very destroyed) 1/8 NPT input. I'm not really sure how a lathe assists with that, and also don't know anybody with a lathe, nor specifically what I would want to buy. I'm not really sure how adding additional adapters creates a better, more leak proof resilient seal here.
