BMW parts will be dear if you ever needed them.
Brother had one from the 70's and to fix it back up the orginal look was going to cost $9,000 in parts alone,  that's nothing installed, fitted etc.
yeah, I know... my old car (before my GTSt) was a 323i - rebuilt as a 2.9L
spent Sh!tloads on it... still miss my baby :D
Most hardcore M3... i think the E46 BMW M3 CSL would have to be competing for that.
What are the specs for the E30 M3, weren't they running 4 cylinder engines?? End still keeping up with/winning some Group A events?
cheers.
Saw a M3 CSl at the golf club a few weeks back, QLD plates. 19" rims, those semi-slicks, carbon fibre everywhere :drools: One of THE best street cars i've ever seen. He/She was one of 21 VERY lucky ppl in this country.
i work for bimmer :rofl:
e30 m3s are 6 cylinder, and they are rare!
be careful when importing from uk - they can get rusty underneath from all the salt and snow .
E30s are definitely 4s. they're a 2.0 or a 2.2 inline 4, the evolution is maybe bigger, 2.5?
I am 100% sure they are not a six. only the 320i, 323i and 325i were sixes.
The M3 motor shared nothing with the 318i motor; the E30 M3 motor is designated "S14" - it is basically the M5 motor of the E28 with two cylinders lopped off. :P
It will be a fine day when i walk into my garage and see a VL Walkinshaw, Sierra, R31 GTS-R plus some American muscle. Hadnt thought too much about the little M3, suppose ill have one of them too.
Come to think of it, a friends dad had a Veal Schnitzel E30 325is, or was that Schnitzer? That was a nice car, one of those will do in right hook at half the price, perhaps with soem wild ass cams to get the banshee NA 6 cuylinder thing happening :rofl:
ahhh you are rite! i've never seen an e30 M3 in the workshop, but i've heard of the S14 engines. They are a 2.3L 4 valve inline. the e36 came with the 6 (S50, 3.0L/3.2L)
bimmer parts are sorta expensive, but you save alot if you do the work yourself. our workshop rate is $115.00 an hour, and its about that much for BMW dealerships anywhere. The e30's are pretty reliable and are better designed than the early E36's anyways.
you know you want one of these...
V8 1990 celsior (lexus GS400) with a 200 lexus makeover and widebodykit... only $23000 to land here.
I think the GRP A M3 that was raced here was a 3 series fitted with the M3 motor cause back then BMW never sold the M3 version. Maybe the reason for not selling the M3 here is cause they were all LHD and the M3 raced here was a standard 3 series chassis with the M3 engine.
Nope, they were fully imported Group A-spec M3s built from the ground up by BMW M-Sport GMbH. If you raced in International Group A, you could run an M3 anywhere in the world (just like the Sierra Cossie).
And AC Schnitzer are a BMW tuning house, on par with HKS, TRUST or Blitz. Long history of sheisse-hot Beemers.
There's a fair few E30 M3s doing the rounds in Oz, with at least 25 registered. Still the most pure, most focused 3 Series ever.
thats nice... should have kept it!  have you seen the new 6 series yet?
I sold it to a guy who lives 2 streets from me... everytime I see it I get sad
you're right - should have kept it :)
The new 6 series is... different. Not sure about it yet, will have to wait and see
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
