Hey guys, im chasing a bottle of German made "freisengeist" schnapps... Ive found an importer and thats gonna cost me about 100 delivered. Just wondering if any fellow drunks knew of a store who might stock?
http://www.nicks.com.au/friesengeist-liqueur-700ml
  • 10 months later...
