I've had e boost, never again, HKS EVC
You generally get what you pay for
Not always true, I had a HKS EVC and it was the most unreliable POS on the planet, it was replaced by the Greddy and the car now has a better boost curve...
https://www.sau.com.au/forums/topic/427056-ebc/#findComment-6892086
That's right thats why I said generally, I have two EVCs now ( 4 & 5 ) and never had an issue, but both came up at good prices when I needed something, so either I've had a good run or your one had an issue, who knows but I know I'd wouldn't ever go the e boost, I spent hours setting up and CRD tried and no matter what we did it wouldn't catch how quick the 32 came on boost, fitted the EVC and with no setting it up had no more problems, been in car for 8-9 years so far
https://www.sau.com.au/forums/topic/427056-ebc/#findComment-6892206
eBoost = great, but overpriced considering it's is just using a MAC valve
Profec = great, decent is price, uses the same MAC valve as most controllers
EVC = awesome, stepper motor holds boost well
Blitz Dual Spec-R = awesome, dual solenoid holds boost so flat you could put a ruler on it
Turbosmart Dual stage = junk, awesome spike
Turbosmart Single stage = junk, awesome spike
https://www.sau.com.au/forums/topic/427056-ebc/#findComment-6893160
A mate had plenty of issues with the original series, in saying that i believe the retard tuner was partially to blame!
Yep i know a few that swear by them hence my purchase, as usual i am just unlucky lol
ive noticed alot of people running greddy profec ebc's are they way to go, hold boost like they should?
Yep, do the job fine! Work well on my car!
:laugh:
https://www.sau.com.au/forums/topic/427056-ebc/#findComment-6893172
^ true story, my 180 came with one, first mod was to remove it and sell it. Then my current shitbox came with one, removed it the first day I got the car, and sold it on eBay.
Biggest croc of shit on the planet, essentially it's just a pos bleed valve with a solenoid to enable the bleed or not.. total shit, however their external gates are good. They should stop making boost controllers LOL
https://www.sau.com.au/forums/topic/427056-ebc/#findComment-6893203
A gate technically controls boost, so therefore would be a boost controller? :blink::laugh:
https://www.sau.com.au/forums/topic/427056-ebc/#findComment-6893206
thanks for your advise guys appreciate it. I'm thinking i might go with the Greddy ebc that option seems good value for cost.
I have researched before but it is easier to ask the question and get direct answers instead of sifting through junk on the net.
thanks for the help matt.
https://www.sau.com.au/forums/topic/427056-ebc/#findComment-6893868
You should be right with the Greddy...
https://www.sau.com.au/forums/topic/427056-ebc/#findComment-6893897
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
