Previous Thread:
http://www.skylinesaustralia.com/forums/topic/392177-wrecking-1995-r33-gtr-midnight-purple-non-v-spec/page-10
..and I still have a ton of parts here!
If it isn't listed below chances are it's there so please PM.
Car is stored outside so I am reluctant to sell glass, doors, boot lid, etc..
Located in Boronia (SE Melbourne) however happy to freight.
Contact via PM.
FOR SALE:
- 215/45R17 87W Toyo Teo Plus Tyres (Brand New - Set of 4) - $400
- GTR Front Pipe - $160
- Front Driveshafts (require driver side inner) - $120 pair
- Original CD Stacker from R33 GTR (with remote & Loom) - $50
- K & N Air Filter Service Kit (1 and a 1/2 kits) - $20
- Speaker Grille's (Hertz, Focal & Response) - $30 the lot
- Rear Reo - $120
- Rear Garnish - $80
- Front Door Trim (Driver) - $120
- Rear 1/4 Door Trims - $80 each
- Rear 1/4 Upper Trims (C-Pillar) - $60 each
- Electric Window Motors - $120 each
- Passanger Electric Window Switch - $50
- Dash - $220
- Centre Console - $120
- Interior Carpet - $120
- Seat Belts - $60 each
- A Pillar Trims - $50 each
- Roof Lining - $120
- Standard upper arms - $160 pair
- Standard uprights - $160 pair
- Front Crossmember - $220
- ABS Unit - $350
- Windscreen Wiper Motor - $80
- Windscreen Wiper Arm Linkages - $80
- Instrument Cluster Surround - $50
- Brake Master Cylinder - $120
SOLD:
Clutch Master Cylinder
Fuel Tank & Pump
Engine & Gearbox
Exhaust
Intercooler & Piping
Airbox
BOV's & Return
PS Pump
A/C Setup
Wheels
Brakes
Brake Air Ducts
Hubs
Struts
Lower & Upper Arms (Front)
Castor Rods
Sway Bars
Rear Driveshafts
Steering Column
Steering Rack
Strut Braces
Tailshaft
Rear Subframe
Underbody Bracing (Rear)
Diff
Atessa Pump & ECU
Relay/Fuse Box
Boot Trims, Plastics, & Carpet
Boot/Fuel Release Cable
Locks & Keys
Spare Tyre
Jack & Mount
Series 3 Xenons
Front Lip
Front Grille
Front Indicators
GTR Wing
Sideskirts
Side Mirrors
Fuel Cap Flap
Bar Skin (Rear)
Bonnet Lining
Guard Lining
Antenna
Seats
Seatbelt (Driver)
Steering Wheel
Instrument Cluster
Sunvisors
Front Door Trim (Passanger)
GTR Coin Slot Cover
Driver A Pillar Trim (Driver Side)
Electric Window Switch (Driver Side)
Floor Mats
Heater Box
Heater Core
Gyro behind Airbag
Airbag Sensor
Triple Gauges
Manual Surround
Head Unit
Cheers - Chris
  • Replies 67
correction to above...
Brake Master Cylinder - $120 is actually meant to read Brake Booster - $120.. must have had a brain fade..
  • 3 weeks later...
  • 3 weeks later...
  • 3 weeks later...
Did the front bar sell mate?
Is it actually destroyed or just scrapped and no lip?
Thanks
hi adam,
yes i still have the front bar skin and definitely repairable just depends how keen you are to repair it.
Do u still have the engine bay fuse box?
contents of fuse box there but plastics assembly itself is gone.
cheers,
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
