Previous Thread:
http://www.skylinesaustralia.com/forums/topic/392177-wrecking-1995-r33-gtr-midnight-purple-non-v-spec/page-10
..and I still have a ton of parts here!
If it isn't listed below chances are it's there so please PM.
Car is stored outside so I am reluctant to sell glass, doors, boot lid, etc..
Located in Boronia (SE Melbourne) however happy to freight.
Contact via PM.
FOR SALE:
- 215/45R17 87W Toyo Teo Plus Tyres (Brand New - Set of 4) - $400
- GTR Front Pipe - $160
- Front Driveshafts (require driver side inner) - $120 pair
- Original CD Stacker from R33 GTR (with remote & Loom) - $50
- K & N Air Filter Service Kit (1 and a 1/2 kits) - $20
- Speaker Grille's (Hertz, Focal & Response) - $30 the lot
- Rear Reo - $120
- Rear Garnish - $80
- Front Door Trim (Driver) - $120
- Rear 1/4 Door Trims - $80 each
- Rear 1/4 Upper Trims (C-Pillar) - $60 each
- Electric Window Motors - $120 each
- Passanger Electric Window Switch - $50
- Dash - $220
- Centre Console - $120
- Interior Carpet - $120
- Seat Belts - $60 each
- A Pillar Trims - $50 each
- Roof Lining - $120
- Standard upper arms - $160 pair
- Standard uprights - $160 pair
- Front Crossmember - $220
- ABS Unit - $350
- Windscreen Wiper Motor - $80
- Windscreen Wiper Arm Linkages - $80
- Instrument Cluster Surround - $50
- Brake Master Cylinder - $120
SOLD:
Clutch Master Cylinder
Fuel Tank & Pump
Engine & Gearbox
Exhaust
Intercooler & Piping
Airbox
BOV's & Return
PS Pump
A/C Setup
Wheels
Brakes
Brake Air Ducts
Hubs
Struts
Lower & Upper Arms (Front)
Castor Rods
Sway Bars
Rear Driveshafts
Steering Column
Steering Rack
Strut Braces
Tailshaft
Rear Subframe
Underbody Bracing (Rear)
Diff
Atessa Pump & ECU
Relay/Fuse Box
Boot Trims, Plastics, & Carpet
Boot/Fuel Release Cable
Locks & Keys
Spare Tyre
Jack & Mount
Series 3 Xenons
Front Lip
Front Grille
Front Indicators
GTR Wing
Sideskirts
Side Mirrors
Fuel Cap Flap
Bar Skin (Rear)
Bonnet Lining
Guard Lining
Antenna
Seats
Seatbelt (Driver)
Steering Wheel
Instrument Cluster
Sunvisors
Front Door Trim (Passanger)
GTR Coin Slot Cover
Driver A Pillar Trim (Driver Side)
Electric Window Switch (Driver Side)
Floor Mats
Heater Box
Heater Core
Gyro behind Airbag
Airbag Sensor
Triple Gauges
Manual Surround
Head Unit
Cheers - Chris
  • Replies 67
correction to above...
Brake Master Cylinder - $120 is actually meant to read Brake Booster - $120.. must have had a brain fade..
  • 3 weeks later...
  • 3 weeks later...
  • 3 weeks later...
Did the front bar sell mate?
Is it actually destroyed or just scrapped and no lip?
Thanks
hi adam,
yes i still have the front bar skin and definitely repairable just depends how keen you are to repair it.
Do u still have the engine bay fuse box?
contents of fuse box there but plastics assembly itself is gone.
cheers,
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
