Previous Thread:
http://www.skylinesaustralia.com/forums/topic/392177-wrecking-1995-r33-gtr-midnight-purple-non-v-spec/page-10
..and I still have a ton of parts here!
If it isn't listed below chances are it's there so please PM.
Car is stored outside so I am reluctant to sell glass, doors, boot lid, etc..
Located in Boronia (SE Melbourne) however happy to freight.
Contact via PM.
FOR SALE:
- 215/45R17 87W Toyo Teo Plus Tyres (Brand New - Set of 4) - $400
- GTR Front Pipe - $160
- Front Driveshafts (require driver side inner) - $120 pair
- Original CD Stacker from R33 GTR (with remote & Loom) - $50
- K & N Air Filter Service Kit (1 and a 1/2 kits) - $20
- Speaker Grille's (Hertz, Focal & Response) - $30 the lot
- Rear Reo - $120
- Rear Garnish - $80
- Front Door Trim (Driver) - $120
- Rear 1/4 Door Trims - $80 each
- Rear 1/4 Upper Trims (C-Pillar) - $60 each
- Electric Window Motors - $120 each
- Passanger Electric Window Switch - $50
- Dash - $220
- Centre Console - $120
- Interior Carpet - $120
- Seat Belts - $60 each
- A Pillar Trims - $50 each
- Roof Lining - $120
- Standard upper arms - $160 pair
- Standard uprights - $160 pair
- Front Crossmember - $220
- ABS Unit - $350
- Windscreen Wiper Motor - $80
- Windscreen Wiper Arm Linkages - $80
- Instrument Cluster Surround - $50
- Brake Master Cylinder - $120
SOLD:
Clutch Master Cylinder
Fuel Tank & Pump
Engine & Gearbox
Exhaust
Intercooler & Piping
Airbox
BOV's & Return
PS Pump
A/C Setup
Wheels
Brakes
Brake Air Ducts
Hubs
Struts
Lower & Upper Arms (Front)
Castor Rods
Sway Bars
Rear Driveshafts
Steering Column
Steering Rack
Strut Braces
Tailshaft
Rear Subframe
Underbody Bracing (Rear)
Diff
Atessa Pump & ECU
Relay/Fuse Box
Boot Trims, Plastics, & Carpet
Boot/Fuel Release Cable
Locks & Keys
Spare Tyre
Jack & Mount
Series 3 Xenons
Front Lip
Front Grille
Front Indicators
GTR Wing
Sideskirts
Side Mirrors
Fuel Cap Flap
Bar Skin (Rear)
Bonnet Lining
Guard Lining
Antenna
Seats
Seatbelt (Driver)
Steering Wheel
Instrument Cluster
Sunvisors
Front Door Trim (Passanger)
GTR Coin Slot Cover
Driver A Pillar Trim (Driver Side)
Electric Window Switch (Driver Side)
Floor Mats
Heater Box
Heater Core
Gyro behind Airbag
Airbag Sensor
Triple Gauges
Manual Surround
Head Unit
Cheers - Chris
  • Replies 67
correction to above...
Brake Master Cylinder - $120 is actually meant to read Brake Booster - $120.. must have had a brain fade..
  • 3 weeks later...
  • 3 weeks later...
  • 3 weeks later...
Did the front bar sell mate?
Is it actually destroyed or just scrapped and no lip?
Thanks
hi adam,
yes i still have the front bar skin and definitely repairable just depends how keen you are to repair it.
Do u still have the engine bay fuse box?
contents of fuse box there but plastics assembly itself is gone.
cheers,
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
