Noooo~!
I'd love to go.. unfortunatly my car is not ready, and I am out of state.
Damn Man! I was going to say bring the bike or something, you away for work? Sooner you get your ass back in NSW and get your nugget sorted the better!
already offered him the gunners seat in the money pit, he hasnt accepted. ...
Haven't rejected the offer either
He obviously doesnt like walking :ph34r:
This!
We could all meet at the truck stop at the start of old pac......
That could work. May be in a Mazda 2 or a N16 Pulsar....
Want to come to this - Sydney side. Will look into the meet up points for a nice drive up with you guys.
Good stuff! Hope you can make it!
Cameras will be out for this event, plenty of pics for all in attendance :yes:
Hey new to this forum im from sydney Just got myself a r33 gtst. Ill be in for the cruise.
That's a good way to begin on your first forum post :)
There's even a Tech Night tonight about Servicing should you become a Member on arrival!
Good stuff! Best was to get to know the guys is to come cruising :D If you want to attend events such as circuit, hillclimb, tech nights or any official events just let us know and we will show you how to become an SAU NSW member :yes:
For now, meet up with the Sydney guys and come enjoy some nice roads!
Yeah keen to become a member.
What with the tech nights?
There is one tonight, basically a workshop hosts a night and educates us or shows us how things are done! Tonights is servicing/maintanance and engineering i think! You keen on coming? Its generally members only from memory but if you want to come and fill in the forms etc its a good start *hint hint* haha
Haha
what time and where is it?
I have something on to a bit later today.
But if I can't make it to this one ill come to the next
Haha
http://www.skylinesaustralia.com/forums/topic/426197-s-a-u-n-s-w-tech-night-for-members-5th-july-servicing-blue-slips-eng-certificates/
Lol and bring it to the cruise?
Yes Tony, just walk into a Nissan Dealership in your pinstripe suit > Keys to the new Nissan Pulsar SSS > Tony disappears for 4 hrs hehe...
Then you've got 4 hrs to think up an excuse as to why you're not buyin' it!
eg broken engine mounts
eg control arm bushes cracked
eg worn synchro on 2nd
I'll meet you guys at the halfway point on putty road. I'm leaving from Mcdonalds on windsor and grove ave, and heading up putty rd, will probably leave Macca's at around 10am to get at halfway point for 11:30am
sounds like a good idea, if I come ill meet up with you there!!!
I'm with you Ciaron & in time for brekky.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
