Got a mate's new 25/30 running today but the oil pressure seems to be a lot higher than it should. Was over 100psi at cold idle. It's currently got running in oil in the engine and has 2 x1.5mm oil restrictors to the head and I'm 99% certain a RB25 oil pump. The vct has an external feed to it but isn't wired up. I'm running a 25 pump on my RB30 and its only got around 60psi at cold idle. Is there any logical reason why it would be running such high pressure?
Also the vct feed is a -4 line. Does it need a restrictor in it at all or will it not matter as we most likely won't be wiring it up so the oil will just drain back to the sump
Edited by PSI086
https://www.sau.com.au/forums/topic/427432-rb2530-high-oil-pressure/
The oil is a Penrite running in 20/50. Going to run a 10w in it once its got a few km's on it and is ready for synthetic though. Might just see what the pressure is like with the proper oil and normal running temperature. I can't see any reason why it would be higher than a normal RB25 as everything is identical besides the lack of oil squirters under the pistons
Just got the car running with the RB20 tune which was in it previously so can't really take advantage of the vct just yet. Will most likely wire it up though. From what I understand it just needs to be activated with an rpm triggered relay?
  • 7 months later...
sorry to bring up the dead guys but im going though the same drama at the moment with my rb25/30 non vct that's just being built and getting tuned
120psi on cold startup and idled at 1500 on penrite running in oil. this seems worrying!!!???? potential to blow seals etc?
im reading this from a auto meter prolite mechanical gauge.
not sure what the warm oil pressure will be just yet as I haven't let it get to that stage yet.
the oil pump is a rb25det pump with billet gears.
block has 2x 1.3mm restrictors and the vct line is disconnected.
ANY IDEAS ON A FIX??
oh shit! that's high for cold start!! once warm that aint to bad! wat oil ?
at what point do we start thinking f**k that's dangerous could blow rear main and front seals etc?
hasn't done any kms, 1st startup was today and after about 10seconds I noticed it was sitting on 120psi at 1500rpm (didn't wana rev any higher plus 1st EVER start up for the engine.
  • 3 months later...
hey all, find any solutions to these 25/30 high oil pressure issues??
my freshly built forged rb25/30 is showing over 100PSI on my autometer mechanical gauge, oil features include:
tomei oil pump
2X1/3mm restrictors
-12 rear head drain
2X-12 sump breathers
2X-12 cam cover breathers
grub screwed VCT feed in head
VCT sensor removed and capped
drilled out oil drains in block
2L accusump
5.5L sump
19row mocal cooler
GREX oil thermostat and oil filter relocation with ryco z145a filter
on penrite running in oil 15w40 it was showing high oil pressure over 100psi on cold start then down to 90 once warm. a tap of the revs to 2500rpm and it went to over 100psi again (gauge only goes to 100psi). after 250kms the oil was drained and a penrite 10w40racing synthetic was put in. once again on cold start over 100psi but once warm it dropped to 80/85psi or there abouts at idle and only went over 100 after 3000rpm
I was thinking of going a lighter viscosity maybe a 5w30synthetic or something? I only use penrite.
could anyone recommend anything?? or does anything look out of place? im a little worried.
I think im going to get a larger scale mechanical gauge to see where there press really sits after 100psi..
I previously had a rb25 pump with billet gears and was showing the same signs
any help would be HUUUUUGELY appreciated im really stumped and worried.
Cheers
Corey
Edited by ScreamerNewbie
If your bearings clearances are all standard then use a standard viscosity oil which I think is a 30 weight?
If you cant get the pressure to drop when warm below say 120psi at full noise where the oil relief is cracked open then you will need to reduce the spring pressure in the bypass of the pump. If you don't want to do that then you can hook up an external Peterson oil pressure regulator between your sandwich plate and oil cooler/filter arrangement and plumb that in so you can regulate the pressure going into the main oil gallery.
  • 3 years later...
On 10/15/2017 at 10:38 PM, pet vl said:
And iam still haveing trouble any idears its my car looking i to changing the spring in the pump HELP
Be more specific...what is your problem? What is the cold oil pressure and how long does it take to drop to say 100 psi?
I see your other post - just post in one place!
See what happens when you compare the spring pressures.
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
