Highest on the day seemed to be a falcon about 335kw, then a STi at 325kw then a GTR at 300kw. Might have been some late entries but nothing big KW.
hmmm.
might have to make some trips when mines running.
you know, since kats now a chicken.
Where's Paul's GTR these days? I thought he'd have dragged it out for an Ultimate tunes day.
Paul had to work but not 100% why his GTR wasnt there. Was hoping for him to have the rx7 finished but that didnt happen.
I only stayed for 3 cars having a run. So didnt stay that long.
Also spotted Verms and his Stag there too.
There wasnt much room in the back of your gtr with the 2 child seats in there. Car looks good tho.
Cheers. Although it was filthy! LOL
The kids have more leg room in the back of the GTR than they do in my XT Foz.
