  • Replies 123
Lithium,
Unlike most of the NZ R33 gtst owners it seems you are actually looking for good advice and are preppared to aim at something (aim at nothing and you hit it every time).Don't worry I'm sure the 12 second pass won't be far off for you either.
That would be cool :) But yeah, realistically in NZ people more often than not short change R33s - so they have hardly been bothered with... most people prefer the R32s, and see them as a better performing car - so thats where more of the knowledge lies, and there is a lot of assumption.
Obviously in Oz you guys are more keen to mod R33s and research ways of getting the better results... so its always good to look where the proven information is, rather than ask people who more often than not don't even like R33s, and in many cases havent even been in them how to mod them - so aren't exactly reliable sources :D
Hey robo...
An ex-LS1'er myself, i congradulate you on the time...
I know the engines in question are worlds apart in how they acheive their goal, and you have done well on your setup...
Im hoping to be there soon also with the stock turbo, although im aiming for 12 psi - just gotta get the funds to finish the project !!
Cheers,
Matt
Guest Robo's
Congrats Robo, awesome time!
Did you leave the tyres at street inflation? Where did you get your clutch from?
Dropped them down to 20psi, dont know if that really helped or what, but done a reasonable burnout to warm them up.
I got my clutch from a guy that sells performance stuff online. Cant even remember how i found him, but send me a PM and i'll give you his number.
Guest Robo's
Exelent Time my car is very similar to yours Everything the same except for FMIC and cam gears. FMIC and cam gears will be my next mod for sure.
Are you running a EBC yet? If not are you holding boost better with new FMIC?
Best without the Cam gears and FMIC was 13.32. No EBC, just a bleed valve, however i did notice slight less boost drop off with the FMIC. Must be called effeciency, it wasnt much though, maybe 1/2 psi.
  • 3 weeks later...
One step closer, raised the boost to 11psi and got it dyno tuned - feels like a completely different car. :P With the current setup I figure very solid 13s should be achievable, I think a bit of work including other-than-power stuff will be needed for a 12 .
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
