Hi gents,
As most V36 owners will know, the spokes on the steering wheel wear and scratch easily, as do the door grab handles that house the power windows. My question is, how have you fixed them? I have a customer keen to get them fixed before he sells his car.
Cheers
Kristian
https://www.sau.com.au/forums/topic/427678-tidying-up-v36-interior-trim-pieces/
I replaced the door handle trim with some new peices out of the US. The price is rediculous for what they are but they are now the brushed aluminium look which suits a lot better.
I have also seen dozens of pictures of peoples scratched up steering wheel controls but honestly dont understand how that happens. I now have 41,000km on mine and they dont have a single scratch on them???
Just wondering which door trim pieces you got? Assume you got 'Infiniti' pieces from the US. Did you have any issues with the left-hand vs. right-hand drive thing?? Not sure what the story is with the coupe but my understanding is these parts on the sedan are different from lhd to rhd.
http://www.ebay.com.au/itm/NEW-OEM-INFINITI-G37-COUPE-DOOR-GRIP-CAPS-LEFT-RIGHT-UPGRADE-/171062104948?pt=Motors_Car_Truck_Parts_Accessories&hash=item27d4189374&_uhb=1
I bought them back when the AUD was at about 1.10 USD. At today's exchange rate the price for two pieces of plastic looks even stupider!
That being said, they do look ten times better than the originals. Mine only really had a couple of scratches on them anyway but I knew that they would be screwed eventually and these look way better.
Damn, was hoping someone was going to have A solution for the scratched up steering wheels...
Seen that there are Infiniti trim kits on eBay, but they all have the hole for the cruise controls...
I'm talking about the trim around the window switches, not that one. Ended up pulling them out and painting them,
Sorry got confused by your original comment "door grab handles that house the power windows". I probably just didn't read the rest of the sentence.
Painting them would probably have been pretty easy. Still not sure how people manage to scratch the crap out of everything so easily? Guess I'm just not 'baller' enough and only wear one ring.
I have a BRAND new in box steering wheel trim piece (the one that wears around the volume controls) I paid good money for it too.
Sold my car and no longer need it. If anyone is interested PM me an offer.
how much are you after for the trim? and is it from the US or japan?
  • 4 weeks later...
  • 7 months later...
I know I'm bringing this one back from the dead a bit but I noticed it while searching for something else. I am sure that while searching MYG37.com before I purchased one that these was a simple fix for the steering wheel surround. The 'Series 1' style surround is a plastic coated with a rubberised type of paint, similar to the Series 1 R33 dash panel. Apparently it scratched fairly easily. I have a few very small scratches on mine near the volume buttons, possibly from rings on someones fingers or finger nails etc. Anyway it sounds like the 'Series 2' surrounds are different, probably due to complaints. It sounded like they weren't using the same coating, ie maybe it it all plastic or proper paint etc. I don't seem to have written down a part number but look for the steering wheel surround from 2009+ and it should be it.
I just had a look and I could only see the Tech package ones from the USA which have the openings for buttons on both sides so they may not suit our version unless you get the extra buttons. Oh, the USA one's will have the extra hole for phone etc on the wrong side. Maybe someone can get a part number for this bezel/trim for the Nissan/Infiniti 2009+?
I thought you would probably have something Chris :)
Just to clarify that is a newer style one that doesn't scratch as easily as the 1st type with the additional holes for cruise? I take it there is no newer version with just the cutouts just on one side for volume and navi/phone etc?
I don't have cruise in mine. There is possibly a thread on it so I'll probably be blasted for not searching. It's not as simple as just hooking up the buttons and cruise is active is it? I know that sounds a little silly but wasn't sure if drive by wire throttle bodies just needed the buttons hooked up to make it work? There might be a separate control module that needs hooking up? If it needs more than that, do you recommend anywhere in VIC for installation?
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
