Hey guys,
I'm trying to build my own oil cooler kit and I need some help with fitting and hoses.
I've bought:
-GREX sandwitch plate with built-in thermostat (-10AN outlets)
-Mocal 19 rows oil cooler core (5/8BSP outlets)
So I'm just wondering what's the best fittings/hoses to use to join both of them up.
I'm thinking of using -10AN braided hoses, so I'll get 2 x -10AN to -10AN hose and 2 x 5/8BSP to -10AN hose? Is that correct?
Also, any recommendations on where I could get them from?
Cheers
https://www.sau.com.au/forums/topic/427723-oil-cooler-fittings/
I used Speedflow fittings and hose (115 teflon / black nylon braid) from motorsport connections in Moorabbin https://www.mscn.com.au
Speedflow seem to be the best fittings I have seen, but check out Proflow as well - I think they are cheaper. Bends etc are not as tight from what I can see but the Speedflow ones are off the planet expensive. A good tip is the straight fittings are much cheaper than any of the bends so if you can get away with a straight its a good thing for the wallet.
Google proflow - lots on ebay and I think you can buy them direct from their website.
Thanks Paul, I've been looking at speedflow and aeroflow, both on ebay. But I can't seem to find any of those fittings for 5/8BSP, as that's the outlet from my Mocal oil cooler... Any recommendations?
Yeah give Motorsport Connections a yell - they haven't failed me yet with being able to adapt to whatever is required. Not sure about ebay but I think Speedflow control the price so generally they retail for same from all dealers.
All the coolers I have dealt with have had AN fittings (JIC) or a metric female boss fitting that you can screw your desired male adapter into. I think you will need an adapter to use the Speedflow stuff on a BSPT but give them a call, tell them what you have to connect and find out your options.
Yeah, my Mocal cooler seems to have a built in male BSP connection..
But will give them a call for sure, as they are close to me too.
Will keep you guys updated :)
Cheers
Mine are all MSCN speedflow! Awesome gear!
^^ +1
I had nothing but issues with Proflow teflon fuel hoses and fittings leaking, TorquesUK has helped me out many times with braided lines for fuel and oil without a problem.
For oil I prefer the black nylon braid rubber cored hoses for oil cooler lines, as it is very flexible compared to the stainless braid. http://www.ebay.co.uk/itm/10-AN10-Nylon-Braided-Stealth-Black-Hose-1m-/170690866285?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27bdf7ec6d
here's my Mocal & GReddy GREX setup:
http://www.trak-life.com/diy-r33-skyline-oil-cooler-with-thermostat/
I went for a Mocal core with dash fittings rather than BSP (which might cost less, but cost more after converters, etc.)
Had a really really good search for fittings... RARELY anything for the 5/8" male outlet on the cooler...
BUT, I did find 5/8" BSP female to 1/2" BSP male and speedflow fittings for 1/2" BSP female to -10AN hose.
So I'll be converting my 5/8" to 1/2" then use speedflow 1/2" adapter for -10AN nylon braided hose.
Can anyone let me know if this idea is ok?
​I understand that the more joints I have, the more chance of problems occurring......
So you need something like this... http://www.ebay.com.au/itm/AN-10-10AN-Male-1-2-BSP-BSPP-Female-Adapter-Mocal-Setrab-Oil-Cooler-/380572024115?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item589bdc3d33
But with a 5/8 bsp thread tapped into it? They may not exist, you may have to modify one and run a tap through it. I could probably help you if you can't find something local. Or you could run the adapters if you have the room...
Really depends where you mount the core, if you mount it where I have it, between the a/c condenser & FMIC, left from the a/c condensor fan you will not have much room available to fit 2x convertors and 2x dash fittings. Unless you mount it just before the wheel arch where it's also commonly mounted.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
