9.5 +45 on the front will be interesting, I'm thinking you will need decent sized spacers on the front as well so it doesnt look heaps sunken, may have issues hitting the suspension without spacers as well although im not sure about that
All right I run a 9 +14 on the rear with 3degrees neg camber and rim is out side the guard ,so a 10.5 + 20 with a 7mm spacer is going to stick out 20mm more and have 18mm less clearance inside ???? How's that going to fit? Jet r 31 runs a 9.5 + 25 with a 5mm spacer so they don't fowl his rear coils so that works out to 9.5+20 so yours would have 6mm less clearance to the strut so it would hit and extend 20mm more ?
you 'might' get lucky and get the rear to work with a 7mm spacer (15 would be better to gain you some inner clearance).. below are pics of 18x9.5+0 all round, the car has an s14 cradle fitted (same width as manual stagea) with 3deg negative camber on the fronts and half a degree negative on the rear. the 20x10.5+20 with a 7mm spacer will have the outer edge sitting exactly the same but i've included a pic of the inner clearance i had - which is why i suggested a slightly bigger spacer as the 20" rim in more than likely to foul on the coilover spring seat/spring. with an auto rear cradle you'll be up shit creek.
front will fit with a 25mm spacer, but i'd recommend something like 40mm or so to at least have them match the way the rears will fit.
good luck.
  • Like 1
Hmmm, I have r34 gtr wheels on the car now. There 18x9 +30 all the way round, I just assumed the 20x10.5 +25 would sit 5mm less from hanging out the guard, and thought the front would hang out 15mm more. Why is it so confusing? Can anyone here put me onto a good workshop that will make this work? I will just pay cash so I don't have to stress and do manual labour trying different things.
seems you don't quite understand how how offset and width are related, punch some numbers in to this to get a feel for it http://www.1010tires.com/Tools/Wheel-Offset-Calculator
honestly, if you want the simplest option it would be to buy another pair of the 9.5+45's and run 25mm spacers all round.. then the final result would only stick out just over 10mm more than the current r34gt-r wheels you have on your car now.
This is what i have to deal with, rears fit nicely. Hang out abit tho, gonna buy the right tyres for rear soonish.
Fronts i need spacers maybe 10mm to clear the brakes or even 7mm. plus i need the right tyres also, i will be stretching tyres to go on these rims, only option i have really......
took some shit pictures of my brakes on front my apologies.
they suit the red perfectly, but i guess it depends how you define 'fit'. i think you'll still run in to dramas with the rear, more-so the inner clearance - have you checked? only reason i ask is because we've all seen the tell tale marks of metal to metal contact on the threads of rear coilovers in these things from running ~9.5+15 when going over bumps (ie gaining more camber when the suspension compresses) and a 10.5+25 has 23mm less clearance, so those wheels would have to be sitting pretty darn close already..
theyll fit easy with a narrower tyre and some camber. would roll your guards to be safe too
as above, camber isn't an option with the little clearance he'd already have to the rear strut
big +1 on the big brake kit!
    • Yep, it was only an option on the Q50 Hybrid.  Same in Japan as far as I know. And doesn't use a centre diff like the Suby's do, so not the same as the WRX.  But it also isn't a reactive AWD like other Nissan AWD vehicles are, eg. Murano/Xtrail/etc.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
    • I'm getting PTSD flashbacks seeing that name again.  With my turbo swift, I got 1,500km of street use on a Jim Berry clutch before it exploded and took out my input shaft with it.
