9.5 +45 on the front will be interesting, I'm thinking you will need decent sized spacers on the front as well so it doesnt look heaps sunken, may have issues hitting the suspension without spacers as well although im not sure about that
All right I run a 9 +14 on the rear with 3degrees neg camber and rim is out side the guard ,so a 10.5 + 20 with a 7mm spacer is going to stick out 20mm more and have 18mm less clearance inside ???? How's that going to fit? Jet r 31 runs a 9.5 + 25 with a 5mm spacer so they don't fowl his rear coils so that works out to 9.5+20 so yours would have 6mm less clearance to the strut so it would hit and extend 20mm more ?
you 'might' get lucky and get the rear to work with a 7mm spacer (15 would be better to gain you some inner clearance).. below are pics of 18x9.5+0 all round, the car has an s14 cradle fitted (same width as manual stagea) with 3deg negative camber on the fronts and half a degree negative on the rear. the 20x10.5+20 with a 7mm spacer will have the outer edge sitting exactly the same but i've included a pic of the inner clearance i had - which is why i suggested a slightly bigger spacer as the 20" rim in more than likely to foul on the coilover spring seat/spring. with an auto rear cradle you'll be up shit creek.
front will fit with a 25mm spacer, but i'd recommend something like 40mm or so to at least have them match the way the rears will fit.
good luck.
  • Like 1
Hmmm, I have r34 gtr wheels on the car now. There 18x9 +30 all the way round, I just assumed the 20x10.5 +25 would sit 5mm less from hanging out the guard, and thought the front would hang out 15mm more. Why is it so confusing? Can anyone here put me onto a good workshop that will make this work? I will just pay cash so I don't have to stress and do manual labour trying different things.
seems you don't quite understand how how offset and width are related, punch some numbers in to this to get a feel for it http://www.1010tires.com/Tools/Wheel-Offset-Calculator
honestly, if you want the simplest option it would be to buy another pair of the 9.5+45's and run 25mm spacers all round.. then the final result would only stick out just over 10mm more than the current r34gt-r wheels you have on your car now.
This is what i have to deal with, rears fit nicely. Hang out abit tho, gonna buy the right tyres for rear soonish.
Fronts i need spacers maybe 10mm to clear the brakes or even 7mm. plus i need the right tyres also, i will be stretching tyres to go on these rims, only option i have really......
took some shit pictures of my brakes on front my apologies.
they suit the red perfectly, but i guess it depends how you define 'fit'. i think you'll still run in to dramas with the rear, more-so the inner clearance - have you checked? only reason i ask is because we've all seen the tell tale marks of metal to metal contact on the threads of rear coilovers in these things from running ~9.5+15 when going over bumps (ie gaining more camber when the suspension compresses) and a 10.5+25 has 23mm less clearance, so those wheels would have to be sitting pretty darn close already..
theyll fit easy with a narrower tyre and some camber. would roll your guards to be safe too
as above, camber isn't an option with the little clearance he'd already have to the rear strut
big +1 on the big brake kit!
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
