Rears went straight on no spacers at all. they do stick out tho, i had to put 245s on rear. needed to stretch. 275s didnt give me any clearance from hitting guards.
Fronts have 30mm bolt on spacers, was running 245s on front but as soon as i left tyre power every now and then i could hear them scraping. Ended up running 225s on front, they still scrape sometimes.
I am gonna have to get all four guards rolled just for some extra clearance, I hate hearing them scrape my guards.
Can anyone help out with a decent workshop for rolling my guards or a business?
Will post some more pics tommorow before footy or after if i get a chance.
Oh and for camber nothing has been touched, so unsure on answering that question 4bidn1
Still can't work out how your rears fit ????? Looks good , shoot us a close up pic of how much the rears stick out , what camber you running
the only thing that would be helping him in this instance is the lack of rear camber from having the car sitting so high, don't forget he's running 20's and still has guard gap which means he'd have next to no rear camber and would create him a little bit of inner clearance, the wheels would be poking probably 25mm from standard guards though. it all comes down to your definition of fitment, which is subjective.
personally i'd still be concerned about contact between the inner wheel and strut though with any weight/suspension travel over bumps etc. can you grab us a pic of how much room you have (with the car sitting on the ground obviously, not jacked up) to satisfy my curiosity?
his rear would look pretty similar to this (18x9.5+15 with a 235 sitting at standard height)
and, for reference, just to illustrate how the rear camber responds to the height of your car this is the same setup lowered
Too be honest i wasn't going for the stretched look to start with, I really have had no choice but too.
For these rims to fit i have done what needed to be done, my next option is to get all guards rolled for some extra clearance.
Further down the track i might come across a cheap pair of fronts for the rear.
At the end of the day this isn't my daily, and i am happy with how it is for now.
Thanks for your mixed comments and help over the thread people, footys nearly over for me so i might even turn up on a cruise one day so you can all bag me about my stretched tyres haha......
Edited by 2000 RS
Someone has to be the pioneer!
I struggled with a guard roller to get my 9in rims covered and ended up getting better results with a piece of pipe between the tyre and guard (once I worked out what Yokatas quote about "baseball bat is your friend" meant).. In order to accommodate 10in rims I think you would have to follow Psymin's example and get the guards extended at a panel shop.
+1 not a huge fan of the stretch mate, but at the end of the day, I can see where you're coming from. Someone had to do it first right, and it is your car in the end!
Would look EPIC with fat tyres and flares IMO.
Cheers,
Shaz
  • 7 months later...
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
