Ay yo! Does anyone know how to easily remove the black soot from the rear bumper without using so much elbow grease, or is there a reason why this happens and how can/ if you can stop it.
My engine has been modified with the usual things, or is there something possibly wrong with the engine
I've seen it on other cars as well, that have been modified so wonder if it annoys them just as much.
Questions, thoughts, answers? :geek:
https://www.sau.com.au/forums/topic/428125-black-soot-buildup/
So is that why i see a lot of white smoke come out of my exhaust when i leave work, i try not to give it gas, but when i even give it the slightest,it spewin out a 40 year olds smokers cough.
I need a mechanical answer to make the engine run right
White smoke... no good... :unsure: I'd get that checked up.
The black stuff should be concentrated around your bumper and boot, might just be because shes running a bit rich. After a wash it takes a few days for that stuff to build up again behind my car, if you leave it on for a long while you'll need to use a clay bar to get it off, otherwise a wash or a wipe with a detailer spray should suffice.
I don't know but i would say it looks more like exhaust fumes, heavy exhaust fumes under load, not white smoke, that was a bit of over exaggeration.
But it looks bad in the rear view and i wouldn't like to be behind me when that happens.
If i got a retune and made it run lean/leaner, would it
A. Reduce the black soot
B. Reduce hp
C. Make the engine struggle for fuel
D. Get more KM's out of a tank of fuel
This is not a game show.
Also just tried a wax and grease remover from repco and WD40 on bumper and came up tits..................that sounds weird.
turtle wax bug and tar remover - best thing i have ever used.
I'm probably one of the most anal people on here when it comes to keeping the car clean and this stuff for this purpose is farken amazing. And completely safe as designed to clean and be gentle on paint.
  • Like 1
Agreed +1
I tackled this yesturday, i havn't taken before and after pictures because i really didn't know it'd go so well, but my results were brilliant =). I'll just number my steps below:
1. Washed car day before.
2. Quick wipe with microfibre cloth and Meguiars quick detailer to remove loose dirt/soot.
3. Clayed the boot lid and rear bar with Mother California clay bar kit (love it).
Breaking away from the steps, there's something i need to point out. Looking right at the paint, on the boot lid there are many small black spots kinda stuck to the paint, only a clay bar can take it off. My 33 is white so i can see them easily. On the bumper the story is a little different, especially just above the exhaust exit, there seems to be a dark yellow stain covering 45% or so of the bumper. The clay bar takes this off, but very slowly, step 4 REALLY helped here.
4. I applied a bit of Meguiars Paint Cleaner with a foam applicator pad, then polished it with a $60 polisher wearing a woolen pad. I also went over it by hand with a microfibre towel, and the result was exactly what i was hoping for, complete whitenesss! I guess this product can be substituted with the turtle wax bug and tar remover, but i have not tried it for this application.
5. Meguairs Ultimate compound, buff, wipe off.
6. Meguairs nex gen tech wax 2.0.... apply, wait, buff off... mmmmmm sily smooth whitenessssss.
I really love the results, and it did not take too long either, maybe 25mints, and soooo worth it. Now i just need to see how long it lasts and also how easy it will be to remove the next buildup with the wax protecting the surface.
Just to let you guys know, when cleaning headlights its never worth using single products i.e. bug and tar remover, brasso bla bla bla... it might clean it, but after a few weeks yellow fever will hit you back hard, and that is because you have not sealed it back. Get yourself the turtle wax headlight restorer kit and spend 30 mints on it, you'll be much happier in the long run! :cheers:
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
