^ Pretty much
Thats why I originally didnt say 'this will definetly be it' but it is most likely one of those things. I suppose if you wanted to test the heat exchanger you could remove the coolant lines, link them together and then run the car and see if the problem gets worse, or if you get oil leakage out of the coolant ports in the heat exchanger. Just let the thing warm up easy
Otherwise if its head gasket/head related then the only option is to pull the head off.
  • Like 1
https://www.sau.com.au/forums/topic/428302-oil-in-radiator/#findComment-6920489
Well, if you want to look at it that way, then yeah, it is an expensive way to diagnose a problem. But I tend toward the expectation that people on here who ask these questions need a mechanic to do the work, so they will then take it to a mech with the "oil in water" story. Whether the head gasket gets replaced or not would then depend on what the mechanic finds.
But I take your point.
https://www.sau.com.au/forums/topic/428302-oil-in-radiator/#findComment-6920541
there is tests you can perform to determine if the hg is blown or not whilst the motor is intact,taking the(factory) hg off usually destroys it and it maybe harrd to pick up where it blew(thats if it blew at all)
its just the way it is
https://www.sau.com.au/forums/topic/428302-oil-in-radiator/#findComment-6920628
Over the course of a weeks driving does it use much coolant?
Not the same car, but my Commodore had similar issues after I replaced the radiator and thermostat, new fluid etc.
I swore I'd done the head gasket, as after a few days there was little bits of oily crap on the rubber of the radiator cap. Then I checked the overflow, and it was in there too.
It was using around 100ml of coolant a day.
I found a heater hose that was a bit loose, and then dumped the coolant and replaced it. Its been fine ever since! The only thing I could think of was either the new radiator had a bit of crap in it, and the fresh coolant might have dislodged some buildup from the engine somewhere.
Check the overflow bottle to see if its got the same stuff in it
https://www.sau.com.au/forums/topic/428302-oil-in-radiator/#findComment-6920670
(to op 2nd answer above )not time to panic yet strongly suggest you get the engine tested before you start tearing the motor down and then having to work out which TAB you can rob to pay for it :-)
Edited by StevenCJR31
https://www.sau.com.au/forums/topic/428302-oil-in-radiator/#findComment-6920679
QUOTE
/QUOTE
Oil in water and combustion gases in water are two separate things though. I don't think there's a "test" that will tell you that your oil in water problem is definitely HG or not.
Edited by GTSBoy
https://www.sau.com.au/forums/topic/428302-oil-in-radiator/#findComment-6920688
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
